20 Most Recent Breville SK500-XL Stainless Steel Cordless Electric Kettle Questions & Answers
3answers
Siemens porsche kettle on/off switch problem
Hi
Make sure that the lid is securely on. Otherwise its the replacement of the auto bi metalic strip which turns the kettle off
8/13/2020 8:32:16 AM • Breville... • Answered on Aug 13, 2020
Breville vkj628 on off switch faulty
Parts for these items are often bespoke and impossible to find. The best option is to replace the kettle with a new one.
8/7/2014 5:39:30 PM • Breville... • Answered on Aug 07, 2014
2answers
Automatic switch off not working when water reached boiling.
There is no do it yourself fix for this problem. However, placing a folded cloth on top of the kettle (covering the spout) will cause it to switch off quicker, as it increases the pressure inside the kettle.
2/17/2013 7:41:30 PM • Breville... • Answered on Feb 17, 2013
2answers
Switch has stopped working, kettle will not heat water
Hi Bruce or anyone else that has this problem.
I had this problem too and after pulling the base off I found that the switch was ok but the problem lay with the two bi-metallic thermal overload switches that are connected to the heating element. I managed to reset them both and now the kettle works fine. This can become an issue if you have accidently boiled the kettle dry once in it's life. Best of luck.
4/14/2012 8:07:21 AM • Breville... • Answered on Apr 14, 2012
Light switch on Breville SK500-XL Kettle
e mail [email protected]
Send them model number
PDC code (on bottom of kettle)
your name and address
where and when device was purchased
They can send you a part or send you a FEDEX label for a warranty repair.
This is a very common problem
2/21/2009 4:10:09 PM • Breville... • Answered on Feb 21, 2009
2answers
Breville Kettle on/off switch Broken
You can try here.
http://www.spares2go.co.uk/browse-BREVILLE-KETTLE-m114-t13.htm
If you do not see it on web site call them here
http://www.spares2go.co.uk/contact.html
Good Luck
1/16/2009 9:21:19 PM • Breville... • Answered on Jan 16, 2009
Intermittently working
That means that there is either a lost contact inside, or a defective switch.
The kettle must be taken apart to fix the problem.
12/27/2008 5:13:29 PM • Breville... • Answered on Dec 27, 2008
Breville model bmo0870 combi error code E08 microwave doesn't heat up, gives an error code half way through a minute
Error 08 is normally an issue with the magnetron or power supply. Not an easy fix. Call an appliance engineer.
3/19/2024 7:13:32 AM • Breville Kitchen... • Answered on Mar 19, 2024
3answers
How do i get the screws out of a breville toaster
I took a 3/16" common (straight) screwdriver bit from one of my cheap universal driver bit sets, chucked it vertically in my shop vice, mounted a grinding disk in my Dremel tool, and ground a 1/16" wide by 1/16" deep slot in the center of the bit. It worked perfectly. A hacksaw blade carefully placed could produce the same tool.
11/12/2023 12:08:25 PM • Breville Kitchen... • Answered on Nov 12, 2023
Breville bb400 manual
I tried that number with no luck
10/13/2023 5:14:10 AM • Breville Kitchen... • Answered on Oct 13, 2023
2answers
Manual for breville BREAd maker BB400
Found it today.. http://www.megafileupload.com/en/file/419286/Breville-Breadmaker-BB400-Manual--CORRECTED--pdf.html
10/13/2023 4:49:55 AM • Breville Kitchen... • Answered on Oct 13, 2023
Our Breville Bakers oven slowed don then shut down at the start of a cycle. The unit looks dead with no life visible. Is this now a throw away item or can it be fixed?
you can call mfg and see if any repair parts are available, however it may be at the end of its life and time for a new one.
1/30/2023 3:37:49 PM • Breville Kitchen... • Answered on Jan 30, 2023
Breville SK500-XL Stainless Steel Cordless Electric Kettle Logo
17 questions posted
Top Breville Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
yarik117
yarik117
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Breville Kitchen Appliances - Others
Most Popular Question
switch stopped working kettle will not
  • Kitchen Appliances - Others
