20 Most Recent
Konica Minolta Konica Bizhub C250 Color Copier, Network Printer & Scanner Scan To Email Questions & Answers
HOW TO RESOLVE CODE C-2221 KONICA MINOLTA BIZHUB C5500
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
Good morning, my Konica Minolta 190f says:please call service 001,what will I do to resolve this
Error code 001 is a generic service call error, and it could be related to various problems within the printer.To resolve this issue, follow these steps:
- Power Cycle: Start by turning off the printer, unplugging it from the power source, and waiting for a few minutes. Then, plug it back in and turn it on again. Sometimes, a simple power cycle can clear temporary glitches.
- Check for Obstructions: Ensure that there are no paper jams or any obstructions inside the printer that may be causing the error. Clear any paper jams carefully if you find any.
- Reset Printer: Look for a reset button or a specific key combination in the printer's manual or documentation. Try resetting the printer to its default settings to see if the error clears.
How to remove white light appeared on artwork in konica minolta buzhub c454
If you have already replaced the charging corona, developer powder, and cleaned the laser unit, but the problem of a white light appearing on the artwork persists on your Konica Minolta Bizhub C454, here are a few additional steps you can take:
- Check the transfer belt unit: Ensure that the transfer belt unit is clean and free from any debris or toner particles. You can gently wipe it with a clean, lint-free cloth. If the transfer belt is damaged or worn out, it may need to be replaced.
- Inspect the imaging unit: Check the imaging unit (drum unit) for any signs of damage or wear. Make sure it is properly installed and securely seated in its designated position. If the imaging unit is defective, replacing it might resolve the issue.
- Perform a density adjustment: The Bizhub C454 usually has a density adjustment function. You can access this in the device's settings menu or through the control panel. Performing a density adjustment might help improve the print quality and reduce any unwanted artifacts.
- Check the print settings: Ensure that the print settings on your computer or the printer's control panel are appropriate for the artwork you are printing. Adjust the print quality, resolution, and any color settings as needed.
- Update the firmware: Visit the Konica Minolta website and check if there are any firmware updates available for your Bizhub C454. Updating the firmware can sometimes address software-related issues that may be causing the white light problem.
If none of these steps resolve the issue, it is recommended to contact Konica Minolta's customer support or a certified technician for further assistance. They will have specialized knowledge and tools to diagnose and fix the specific problem with your machine.
