20 Most Recent Maytag MDE2400AYW Neptune Electric Dryer Questions & Answers
2answers
Maytag Neptune dryer displays 88 and won't start
our dryer just keeps running and doesnt not shut off after cycle is done. You have to unplug or open door for it to shut off. This is not a refurbished dryer we had bought brand new
2/12/2019 1:03:52 PM • Maytag... • Answered on Feb 12, 2019
Was drying a load of
Good morning to you
I would clean all the fluff from the dryer.
Enjoy your coffee
Kolbrun
1/25/2018 6:35:26 AM • Maytag... • Answered on Jan 25, 2018
Maytag stack front loading compact dryer mde2400ayw won't start
try unpluging it for awhile might reset its self if not board would need replaced
5/6/2017 2:00:06 PM • Maytag... • Answered on May 06, 2017
I have a Maytag Commercial electric dryer in my home ,brand new sat for 2 yrs,got it to work 3 times,then quit.Computer panel was bad,replaced it,the model # is MDE22PRBYW0 not what's showing above
So then, you have purchased a computer panel that is designed for a "pay" machine., or perhaps for another model than you have. (In that case, the "d5" would mean something else.) Please look at "Sears Parts Direct" on your computer and see what they say as to your replacement panel part number. What I do is then go to e-bay and search the part after I get the correct number. I surely hope Sears will have the schematic for your machine. God bless your efforts.
2/2/2016 1:18:01 AM • Maytag... • Answered on Feb 02, 2016
3answers
Maytag MDE2400AYW Dryer Heating Elements not staying on
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
10/24/2015 11:45:25 PM • Maytag... • Answered on Oct 24, 2015
I took my dryer apart and found a staple on cushion of barrel. I did not remover circuit board and may have damaged something. When torn dryer on the timmer light shimmers and will only dry for 30 mi
sounds like u may have a motor winding going bad will usually run 20-30 minutes then shut off and if u run agin right away it will run 10-15 minutes and shut off agin. run an hour later and u will get 30 minutes or so agin? or u may have bad venting causing an over heating prob
12/9/2014 6:45:24 PM • Maytag... • Answered on Dec 09, 2014
What does error code U361 mean
A "U" code is a generally caused by an unbalanced load. If the dryer is level and has a medium size load causing the error, you may need to have the "Unbalance switch or control board" replaced. As with any electronics, unplug it for a few minutes to reset it and try again.
10/28/2014 9:42:02 PM • Maytag... • Answered on Oct 28, 2014
0answers
0answers
My Maytag Neptune is making a banging sound while
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
1/12/2011 5:54:53 PM • Maytag... • Answered on Jan 12, 2011
Maytag mde2400azw takes forever to
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
12/27/2010 6:31:08 PM • Maytag... • Answered on Dec 27, 2010
My dryer does not heat
defective heater
12/23/2010 8:25:27 PM • Maytag... • Answered on Dec 23, 2010
My dryer gives a 3Ecode
3E == overcurrent detected at the motor.
Open the control panel, there should be a tech sheet in there that explains how to put the machine into service mode (presschimeandextra rinsekeys for three seconds) and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes... and lots of other stuff that'll help you track this down.
You can also go ahead and check out the windings on the motor. Unplug harness connector and test from wire insertion side.
Pin #1 and Pin #2 of CN9 == 11.6 ohms
Pin #1 and Pin #3 of CN9 == 11.6 ohms
Pin #2 and Pin #3 of CN9 == 11.6 ohms
11/26/2010 9:42:31 PM • Maytag... • Answered on Nov 26, 2010
Maytag MDE2400AYW Neptune Electric Dryer Logo
51 questions posted
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
maytag commercial electric dryer in home
  • Dryers
