20 Most Recent DeLonghi 60 CUP COFFEE URN Stainless steel Questions & Answers
Delonghi dcu600t glass knob
Try e-spares they have 1000s of parts Website www.espares.co.uk Phone 0844 9777 888
2/23/2015 8:14:43 PM • DeLonghi 60 CUP... • Answered on Feb 23, 2015
I lost my instruction booklet. How much coffee
On the side of my coffee container it says,
"For all coffee makers.
  • 1 tablespoon 1 serving
  • 1/2 measuring cup 10 servings.
Of course, you can adjust according to your personal preference for coffee strength.
12/5/2010 5:26:27 AM • DeLonghi 60 CUP... • Answered on Dec 05, 2010
Delonghi Magnifca Evo doesn't show "add beans" error. It just continues with the process and makes a weak coffee or just pours hot water.
When was it last dealer serviced? These machines need a service every year. Of course they don't tell you that when you buy them! The hopper sensor needs cleaning or replacing. https://www.google.com/search?q=Delonghi+Magnifca+Evo+doesn%27t+show+%22add+beans%22 ..
4/3/2024 6:56:26 PM • DeLonghi Coffee... • Answered on Apr 03, 2024
Delonghi Ecam 23.450S heating up please wait
'heating up please wait...' and that's it, suggests a fault with either a sensor or a control board... and in today's market, who could ever guess which? I'm sorry this is far more philosophical than technical. I really hate to say this. Still, if any half-way modern appliance has given you 15 years' service, what more would you have expected? Traditionally, you would have taken any faulty gizmo to a local repair expert, who would have fixed it for a charge greatly less than any replacement cost. Today, it's almost inconceivable that the cost of even diagnosing, let alone fixing any fault would be comparable to the cost of replacing (whatever) with a new one.
1/28/2024 7:36:43 PM • DeLonghi Coffee... • Answered on Jan 28, 2024
De'Longhi PrimaDonna XS ETAM. It won't produce steam or take milk from the dispenser, but will make hot black coffee. Any ideas?
This normally happens because the milk supply tube is blocked with congealed, solidified milk. You will need to remove the tube and clean it manually. When you do cleaning, make sure you use a specialty milk line enzyme cleaner like Rinza. https://www.google.com/search?q=delonghi+primadonna+xs+not+taking+milk Steam Valve cleanup https://www.google.com/search?q=delonghi+primadonna+xs+not+producing+steam ..
12/30/2023 12:30:33 AM • DeLonghi Coffee... • Answered on Dec 30, 2023
How do I change the time from military time to back regular time on my Delonghi COM530m coffee maker?
It has always been Military time. https://www.manualslib.com/manual/2073018/Delonghi-Com53-Series.html?page=7#manual and from DeLonghi direct The clock on my BCO combination machine is military time. How can I change it? All BCO's units are designed with a military standard and it is not possible to change it.https://www.delonghi.com/en-us/faqs/search?q=%20Delonghi%20COM530m%20military%20time..
10/31/2023 7:57:46 PM • DeLonghi Coffee... • Answered on Oct 31, 2023
I have a DeLonghi Magnifica coffee machine. The error code 'close door' does not go off even though the service door is closed.
There are some suggestions here, but not as much as I would like. you will probably need to take it to a service centre. These machines need regular dealer service as they are all very unreliable. https://www.google.com/search?q=DeLonghi+Magnifica+coffee+machine+error+code+%27close+door%27+does+not+go+off ..
10/22/2023 4:19:54 PM • DeLonghi Coffee... • Answered on Oct 22, 2023
The error code close door does not go off even if the service door was closed on DeLonghi Magnifica coffee machine
According to the De'Longhi UK website, the error message "Close Door" could be caused by two issues : The brewing unit is not installed properly in the unit. You can try turning the unit off, remove and reinstall the brew unit, and then turn the unit back on to see if it reset itself. The latch on the service door has coffee build up and is restricted from moving freely. Please clean the latch area and make sure the door closes. If neither of these solutions work, you may need to contact DeLonghi support for further assistance.
10/22/2023 4:39:36 AM • DeLonghi Coffee... • Answered on Oct 22, 2023
Delonghi magnifica evo never stops grinding coffee beans
Ground coffee beans can squirrel their way into hard to reach places in a grinder and cause problems. I think it is clogged with grounds. Remove the beans. Reseat the burr (grinder). Reset the adjustment ring to 3. Lock itin place with the silver handle. Reinstall the hopper and beans. Here is a tutorial on more advanced cleaning and maintenance: You can skip the ad. Delonghi Magnifica Evo ' How to clean and maintain - YouTube
10/21/2023 4:27:19 PM • DeLonghi Coffee... • Answered on Oct 21, 2023
Delonghi Magnifica S 22.110 SB (brand new). Coffee comes out, but only a teaspoon quantity after hitting "2 cups long espresso".
Question edited for clarity. Question moved from Cars and Trucks. It shouldn't need calibrating from new, but yours does. These machines are born to fail as they are not commercial quality and need dealer service every 6 months. https://www.google.com/search?q=delonghi+22.110+sb+calibrate+quantity+of+coffee ..
9/3/2023 5:16:59 PM • DeLonghi Coffee... • Answered on Sep 03, 2023
We have a De Longhi coffee grinder KG100. The
First you pry the timer knob off and remove hopper, under the machine there a 4 tabs, using a small screwdriver pry those until the casing slides off. Unscrew the nut holding the timer and take out timer, unplug the terminals, replace or try and repair. Warning there a cogs and springs in there, i was unsuccessful.
8/11/2023 8:14:23 PM • DeLonghi Coffee... • Answered on Aug 11, 2023
Esam6700 hot water spout and milk frother not working:
Based on the information provided, it is possible that there is an issue with the machine's internal circuitry or wiring. It could also be a problem with the control board or the sensors that detect the presence of the milk jug or hot water spout. One possible solution is to try resetting the machine to its default settings. To do this, turn off the machine and unplug it from the power source. Wait for a few minutes before plugging it back in and turning it on again. This may help reset any internal settings that could be causing the issue. If resetting the machine does not work, it may be necessary to have it serviced by a professional technician. They can diagnose and repair any underlying issues with the machine's components. It is also worth noting that regular maintenance and cleaning of the milk frother and hot water spout can help prevent issues from occurring in the first place. Be sure to follow the manufacturer's instructions for cleaning and descaling these parts of the machine. Overall, if the issue persists, it is recommended to contact Delonghi customer support or a certified technician for further assistance.
6/21/2023 8:47:07 PM • DeLonghi Coffee... • Answered on Jun 21, 2023
DeLonghi Esam 4500 stuck in empty grounds container while its empty and inserted
This is the third time in 2 days. Is this the same person HIDING behind 'Anonymous'? Watch videos and read. Or take to a dealer. These home coffee machines need dealer service once a year, but they don't tell you that when you buy them. My machines in a commercial setting serving up to a thousand cups a day were serviced every 3 months. https://www.google.com/search?q=DeLonghi+Esam+4500+stuck+in+empty+grounds+container+while+its+empty+and+inserted Or if you want to ask the question to a DeLonghi technician, go to www.justanswer.com ..
6/10/2023 2:31:23 PM • DeLonghi Coffee... • Answered on Jun 10, 2023
DeLonghi Esam 4500 are stuck at 'Empty Grounds Container' while it is already cleaned and inserted?
This is the second similar issue in 2 days with this machine. This will be a problem with the switch that registers it is there. Help in the link https://www.google.com/search?q=Esam+4500+stuck+at+%27Insert+Grounds+Container%27 ..
6/10/2023 1:57:51 PM • DeLonghi Coffee... • Answered on Jun 10, 2023
DeLonghi Autentica ETAM29.510.B 'The pre-ground coffee funnel is clogged.' error while its not clogged, can I turn of the sensor ?
Now you know why is was a secondhand machine. This type of machine is featured on this website with faults 10 to 15 times a week. They are fully computer operated and the only way to diagnose is usually via a laptop with dealer software, or they just swap out the main control board and/or the sensor and hope for the best. https://www.google.com/search?q=DeLonghi+Autentica+ETAM29.510.B+%27The+pre-ground+coffee+funnel+is+clogged.%27+error ..
4/29/2023 10:31:03 PM • DeLonghi Coffee... • Answered on Apr 29, 2023
De'longhi Eletta coffee machine Steam doesn't come out from the spout?
There is no video? You can only link it to the post if it is on YouTube, or you can put a text link to a place like DropBox. These machines need professional service every 6 to 12 months, but they don't tell you that when you buy one! The appears to be a few different models of Eletta, they seem to be a series. I see one with a milk tank on the left and another that makes two cups with a flat front. If it is leaking from the milk steam spout, they need soaking in a milk enzyme cleaner because the milk gets baked on inside the tube. They also have o-ring seals when one part joins another. https://www.google.com/search?q=de%27longhi+eletta+steam+leaking+water ..
4/15/2023 5:50:04 PM • DeLonghi Coffee... • Answered on Apr 15, 2023
I replaced the water sensor and the magnet is flooding properly in my Delonghi Magnifica XS, but the fill tank light is not litnihg ON when the water level is low. What can be the problem?
If you have already replaced the water sensor and the magnet is functioning properly, there are a few other potential causes for the fill tank light not turning on when the water level is low in your Delonghi Magnifica XS.
  1. Faulty sensor connection: Check that the sensor connection is clean and connected properly. Make sure there are no bent pins and that it is seated correctly in its socket.
  2. Faulty control board: The issue may be with the control board, which could be preventing the fill tank light from turning on even when the water level is low. You may need to replace the control board to fix this issue.
  3. Faulty wiring: Check the wiring for any signs of wear or damage. If you find any, you may need to replace the wiring to fix the issue.
If you have tried these steps and the fill tank light still doesn't turn on, you may want to contact a professional technician for further diagnosis and repair.
4/11/2023 12:22:29 PM • DeLonghi Coffee... • Answered on Apr 11, 2023
2answers
Our Delonghi Magnifica grinds beans but then the ground coffee light comes on and nothing happens
These machines are designed to fail, especially this particular model which is here on Fixya many times a week. The only way to fix is dealer service due to computers and software controlling them.
4/11/2023 12:08:26 PM • DeLonghi Coffee... • Answered on Apr 11, 2023
Coffee Makers & Espresso Machines Logo
Popular Tags
7 questions posted
Top DeLonghi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
DeLonghi Coffee Makers & Espresso...
  • DeLonghi Coffee Makers & Espresso...
Most Popular Question
lost instruction booklet much coffee
  • Coffee Makers & Espresso Machines
