20 Most Recent
Maytag MAH9700AWM Neptune Front Load Washer Questions & Answers
E3 and be error on maytag washer
E3 error code is indicating that the motor should be running but the
hall sensor for the motor is not sensing the turning of the motor.
If the error code comes up all the
time as soon as you press the power on button, then it means your
control board is bad and reading incorrectly. If it only happens during
a cycle, then you need a new motor unfortunately.
Note - You could disconnect the power supply for few
minutes, say 15 minutes and see if that resets the control board and
solve the problem unless follow what was mentioned above.
For replacement instructions you can download this
repair manual for your front load and follow the steps given in the manual and here the
search parts.
Hope helps.
5/17/2011 3:29:08 PM •
Maytag...
Answered
on May 17, 2011
We just installed the MAH9700AWM
The "OE" error code means the control detected the water level in the
machine is above the overflow level. According to your description the
first failure suspect is the water valve possibly stuck. Perform the
troubleshooting as described in the
tech sheets.
Here are the break down diagrams for the Maytag Neptune washer
Model MAH8700AWW
2/26/2010 12:46:48 AM •
Maytag...
Answered
on Feb 26, 2010
