20 Most Recent Maytag MAV7657EW Top Load Washer Questions & Answers
Hello
This is usually due to a bad door switch.The switch is there to stop the washer during the drain and spin cycle when you open the door to prevent injury.
If it is not working prior to drain and spin the machine will not finish.You can jump the switch out but its better to replace it.
Maytag MAV7657EW... | Answered on Jun 25, 2011
Regards, Tony
Maytag MAV7657EW... | Answered on May 22, 2011
There's a PDF with the diagnostics codes here:
http://www.uncleharrywizard.com/nephewclub/wizardwasher/whirlpool-kitchen-aid/vertical-modular-washer-vmw/WTW-MVW%20Washer%20-%20diagnostic%20mode.pdf
Or reach out to these folks to see if the repair manual includes the schematics:
Maytag Washing... | Answered 5 hours ago
check under agitator see if cogs broken will reduce spin or possible motor overheating
Maytag Washing... | Answered 2 days ago
remove agitator and plate then remove clip and plastic piece with screws look under see if gears bad if so order part on amazon
Make sure it is plugged into a GFCI outlet; try adding a surge-protector. The fuse will blow if the power exceeds the rating on the fuse. (If a surge-protector on the GFCI outlet does not prevent this, there will be a problem with the wiring inside the machine.)
Maytag Washing... | Answered 3 days ago
inside agitator 7/16 bolt remove and lift out and plate
Maytag Washing... | Answered on Oct 10, 2019
check to see if drained or spinned out
remove agitator and replace plastic piece with screws to bottom probably stripped gears only about 14 dollars on amazon
Maytag MAV7657EW Top Load Washer Logo
9 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
year matag
  • Washing Machines
