20 Most Recent
Maytag MDE9700AYW Neptune 174 Electric Dryer Questions & Answers
Hi, my Maytag Neptune gas
The thermal fuse is NEVER at fault, it is only a symptom of some other problem and is a serious safety warning. Check that the exhaust vent is clean and not kinked or otherwise obstructed. When WAS the last time you cleaned the vent??
11/3/2017 4:16:16 AM •
Maytag...
Answered
on Nov 03, 2017
Maytag neptune dryer belt off and loose
If belt is not broken, then the tensioner is not routed properly. Generally belt comes around drum, then around tensioner pulley then on motor pulley. Tensioner is spring loaded, so you need to pull up on tensioner to get belt around motor. Good luck.
5/5/2017 2:40:01 AM •
Maytag...
Answered
on May 05, 2017
NO POWER TO DRYER???
Hi there, you are experiencing a power supply board failure. this board may have used all its life up and unfortunately, it will have to be rebuilt or replaced.
1/5/2017 8:42:10 PM •
Maytag...
Answered
on Jan 05, 2017
BTW, where is the fuse for this model number?
You should get 120Vac between the red and the white, the red and the ground. 120Vac between the black and the white, the black and the ground, and 220Vac between the red and the black.
2/17/2015 3:27:57 AM •
Maytag...
Answered
on Feb 17, 2015
Why is water in the dryer vent line
There can be multiple reasons for this. If the vent line exhausts to the outside, it is possible that if the vent louvers are stuck open and rain may enter the line when windblown. More common is that dryer vent air is hot and moist due to the water being evaporated from the clothes. If the vent line runs through a cool/cold area, condensation may form in the vent line. If there are sags in the line, condensed water can accumulate in these places.
9/7/2014 4:39:49 AM •
Maytag...
Answered
on Sep 07, 2014
Wiring diagram
It will usually run through a heat fuse that protects the dryer from overheating.
Best to download and save service manual from this site. Go to troubleshooting section and see if yo can run the diagnostics. The diagnostics code could tell you what is failing. There are component testing procedures listed to go through if the diagnostic code is not helpful.
http://www.applianceblog.com/manuals/16025911.pdf
8/24/2014 9:53:37 PM •
Maytag...
Answered
on Aug 24, 2014
Maytag Neptune Thermal Fuse Location?
Yes, I just changed thermal fuse on the same model . . . take off the front door, the front panel and there it is; attached to the vent tube with a flimsy bracket
8/10/2014 11:17:10 PM •
Maytag...
Answered
on Aug 10, 2014
