20 Most Recent
Gemini Sound Products SBR3B Remote Control Questions & Answers
NO CODE FOR LG TV
try these codes:0060 0393 0032 0400 0055 0024 0240 0025 0579 0737 0270 0239 0454 0313 0186 0201 0384 0629 0132 1957 1949 0721 0738 0846
GEMINI CL033
Code available for free at this address:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=gemini
Hope that helps,
erch.
Universal remote codes
Hi jamie,
did you remember the procedure to scan for the codes ? Normally if your TV is not listed on the manual, you can execute the search mode ponting to the TV. As soon as the TV turns on, press the accept key on the remote. I had the sam problem, luckily I remembered the scan procedure. I have 3 different brand of remote controls, all with scan capability but diffeent key strokes.
Gemini quick 20 need manual and codes
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
