20 Most Recent
Panasonic PV-GS180 Mini DV Digital Camcorder Questions & Answers
Sdhc card in pv-gs180??
The
PV-GS180 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
4/13/2012 12:13:17 PM •
Panasonic...
Answered
on Apr 13, 2012
Need and and all USB
You can use the disc that is provided with the cam install the software from the disc then connect the cam with the PC and wait a while until the driver get installed.
8/18/2010 7:37:12 PM •
Panasonic...
Answered
on Aug 18, 2010
I have a Panasonic NV-GS180GN
You can use windows movie maker to capture videos from the camcorder. Connect it via USB and use the capture from camera option to start the streaming capture. Note that you do not need additional drivers as it detects most camcorders. Just in case if it doesn't let me know and I will get you the link to any additional software that panasonic has to offer.
Sai.
3/23/2010 6:06:07 AM •
Panasonic...
Answered
on Mar 23, 2010
I am having trouble trying to install video stream
Windows XP has the stream uptake profile built right into it. You should not need a driver. Plug your cam into your computer and open movie maker (also built into XP) and it will ask you if you want to import. Click yes and then a drop down tab will apeer just choose your dv devise (cam)
1/28/2010 4:34:48 AM •
Panasonic...
Answered
on Jan 28, 2010
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
11/15/2009 3:38:29 AM •
Panasonic...
Answered
on Nov 15, 2009
