20 Most Recent Panasonic PV-GS39 Mini DV Digital Camcorder Questions & Answers
0answers
I used the wrong camera at work. It is old and I no longer have the software to install the drivers. I need to take the video from the camera to my computer. Can you help?
ftp://ftp.panasonic.com/camcorder/software/motion_dv_studio_v60e_le_software_update.exe
2/10/2015 4:01:51 PM • Panasonic... • Answered on Feb 10, 2015
0answers
Sd card error
Be the first to answer 10/3/2013 5:30:49 AM • Panasonic... • Posted on Oct 03, 2013Be the first to answer
Ppanasonic NV-GS60 LCD not working
Hi.My name is Rick and I am the owner and technician of Discount Camera Repair. The problem you are experiencing is most likely caused by a faulty flex cable that connects the LCD to the camera and can be repaired fairly inexpensively but will require disassembly by a qualified technician. If I can be of any help please call or email me. I'll be happy to repair the camera for you.
1/10/2012 12:52:33 AM • Panasonic... • Answered on Jan 10, 2012
How do you reset the counter when shooting video?
The resetting of the counter is not a problem. As a matter of fact you can not reset it because it is meant to be continuous as long as the video is the same. However there is way around it. After recording your first part when you want to reset you go to 'play'. You play forward for less than a second and stop. When you go back to record the camera resets itself and thinks its starting a new video. It goes back to 000. You keep on doing this when you want to reset again. Normally in professional circles the time code should be continuous for editing with professional Non linear editing software that's why the cameras do not reset the time code. But you can get along the way I have told you here for your purpose.
10/28/2011 1:18:17 PM • Panasonic... • Answered on Oct 28, 2011
3answers
Not able to connect with my PC
no solution ladd . have the same f.. problem.
camera is basically useless!
5/25/2011 11:34:42 AM • Panasonic... • Answered on May 25, 2011
It got a very slight amount of water splashed on
Unfortunately, I had this problem before with a waterproof camera!
Once the water bridged the circuits, it did irreparable damage.
If it had dried out WITHOUT voltage running through the camera, it might not have caused any issues.
Best option is to remove any batteries and power cables, and let it dry out completely. Check to see if the problem persists, and if so, consult the manufacturer for a repair.
2/23/2011 8:13:03 AM • Panasonic... • Answered on Feb 23, 2011
I want to download my
Hi, you can get the drivers here.
1/11/2011 11:44:01 AM • Panasonic... • Answered on Jan 11, 2011
I have a Panasonic PV-GS39
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Whether this will work with Windows 7, I am not sure. My Mini-DV camera, using a Firewire cable, didn't need any camera driver loaded to the computer, just the movie editor that came with Windows XP.
12/8/2010 12:02:41 AM • Panasonic... • Answered on Dec 08, 2010
NECESITO EL DRIVE PV -GS
8/4/2010 5:25:08 PM • Panasonic... • Answered on Aug 04, 2010
I have windows 7 and want to put my movies onto
The chances are that a USB cable from your PC wont work on any windows newer than XP, you like myself will need Firewire cable from a good camera store.
6/11/2010 8:32:04 PM • Panasonic... • Answered on Jun 11, 2010
Where can I get the operating manual for my mini
you can find it right here!
4/6/2010 5:38:57 AM • Panasonic... • Answered on Apr 06, 2010
Cd is not install
instal from computar
3/27/2010 9:43:56 PM • Panasonic... • Answered on Mar 27, 2010
Panasonic PV-GS39 Mini DV Digital Camcorder Logo
84 questions posted
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
PV Panasonic
  • PV Panasonic
Most Popular Question
ppanasonic nv gs60 lcd not working
  • Video Cameras
