20 Most Recent Maytag SAV4655A Top Load Washer Questions & Answers
I have a Maytag A612
Your about right....and getting parts for a 1986 Maytag may be almost impossible. Maytag was sold many years ago and old parts were dumped.
1/31/2018 11:17:16 PM • Maytag SAV4655A... • Answered on Jan 31, 2018
How to replace the brake pads on a Myatg Washer sav515deww
Searspartsdirect.com just input your model number. Look at the figures to find the part needed and order.
9/22/2017 2:17:57 AM • Maytag SAV4655A... • Answered on Sep 22, 2017
2answers
Washing machine tub wobbles violently during rinse
borken sprinng
12/19/2014 1:10:14 PM • Maytag SAV4655A... • Answered on Dec 19, 2014
I have a really old maytag A606 washer. There is a
Have you taken the hoses off and checked to see if there is a screen in the hoses?............or on the machine itself its a longshot but usually there are little mesh screen filters either in the hoses or on the machine itself. If its knocking its either dry (no water) or the solenoid is going bad.Cheap fix possibilty get a Y connector hose and you can mix your hot and cold water in there then just feed it through the hot water side. Or just hook your cold water hose up to the hot water side and just wash with cold water. If you are looking to just get it running and save money.A couple thoughts anyways I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
8/23/2013 2:57:25 AM • Maytag SAV4655A... • Answered on Aug 23, 2013
3answers
My whirlpool washer model LSR6232JQ1 suddenly will
Try to replace the water inlet valve. This valve is located in the back of the machine and in most cases is a blue plastic assemble where the hoses hook up. This can be purchased at any appliance repair shop. Good Luck Hopes it's your cure. dave
9/18/2012 10:49:47 PM • Maytag SAV4655A... • Answered on Sep 18, 2012
0answers
The water pressure is great when the water hose is
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
4/2/2011 3:37:16 AM • Maytag SAV4655A... • Answered on Apr 02, 2011
2answers
Washer will fill with water but when it tries to
Hello & Welcome to FixYa
The hum sound clearly states that the motor is bad and the smell says that the motor needs to be replaced. You can buy the parts here. Please get back to me if you have any other questions.
Kevin
1/24/2011 12:51:51 AM • Maytag SAV4655A... • Answered on Jan 24, 2011
Machine just stopped working. It was due to spin
unplug it for about 15 mins to reset it if not working go to appliancerepairplanet.vstore.ca and u can get a sevice manual on it hope it works out
12/1/2010 7:09:31 PM • Maytag SAV4655A... • Answered on Dec 01, 2010
Need help in replacing a broken belt
First unplug the washing machine to avoid injury while working inside. Remove the bottom access panel by removing the two screws located at the bottom. Pull the panel down and out. This will give you access to where the belt is.
If this helps you out, please vote or leave a comment
11/28/2010 4:28:08 PM • Maytag SAV4655A... • Answered on Nov 28, 2010
Hello ,after using the machine, water keep
Hi Alex. Welcome to FixYa. I am Kelly.
Water leaking by when the unit is supposed to be off is caused by water leaking by the inlet water valve diaphram.
Here is what you can do in an attempt to clear any internal debris of the water valve.
Both wall faucets off
1. Disconnect One hose from the water valve and remove the inlet screen by using a knife blade on the outer edge of the screen.
2, Reconnect that hose to the water valve.
3. Place the wall end of the hose in a bucket
4. Turn on the water at the wall for the hose that is still connected to the wall.
4. Select WARM wash and start a fill cycle. (Water will back flush into the bucket.
5. Use a hammer HANDLE and tap the hose connections of the water valve. (Your trying to losen the debris)
6. After a minute turn off the warm fill and the water faucet at the wall.
7. Disconnect the removed hose from the water valve and install the inlet screen AFTER cleaning the screen.
8 Reconnect the hose to the water valve and the wall connection.
9. Repeat steps 1 - 8 for remaining side.
If this does not stop the water drip then the water valve will have to be changed.
I will repost later the water valve part number and source.
Thanks for choosing FixYa.
Kelly
9/26/2010 10:15:01 PM • Maytag SAV4655A... • Answered on Sep 26, 2010
We have a Maytag A612 washer. Today it wouldn't
Turn off the cold water faucet.
Remove the water hose from the machine and the faucet.
Clean out the filter screen in the washer water valve.
Look in the hose for a secondary screen and clean it also if one if there.
Not all hoses have screens.
All water valves do have screens.
9/12/2010 6:25:04 PM • Maytag SAV4655A... • Answered on Sep 12, 2010
Maytag SAV4655EWW Started making loud noises about
Depending on how old this machine is, I would say if it is 5 years or newer, I would get the wrench, empty and disconnect the machine, tip it on it's side, access the bottom of it, and replace the seal.
6/12/2010 8:41:59 PM • Maytag SAV4655A... • Answered on Jun 12, 2010
Maytag washer won't agitate or spin
Check the lid switch, it can prevent those two operations from working.
6/6/2010 5:18:20 PM • Maytag SAV4655A... • Answered on Jun 06, 2010
My washer only pumps water out for 5 sec and shuts
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
4/26/2010 1:03:28 PM • Maytag SAV4655A... • Answered on Apr 26, 2010
Maytag SAV4655A Top Load Washer Logo
64 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
really old maytag a606 washer
  • Washing Machines
