20 Most Recent Panasonic (BBHGW700A) Wireless Router Questions & Answers
What is the access address
Wireless Encryption Key WEP or WPA -
You will findit on the router itself or open the Router GUI i.e 192.168.x.x page
11/8/2010 6:12:54 PM • Panasonic... • Answered on Nov 08, 2010
2answers
Need to access router. does it have a default ip
if no one changed it, should be something like
192.168.(0 or 1 or 100).(1 or 2 or 100)
if you google your owners manual should have that info too
10/7/2009 3:29:07 PM • Panasonic... • Answered on Oct 07, 2009
My Phone is Panasonic KX-T7730 unable to call another extension
Unplug all the extensions and then plug them back in one at a time. https://www.google.com/search?q=Panasonic+KX-T7730+unable+to+call+another+extension ..
3/17/2024 4:53:10 PM • Panasonic... • Answered on Mar 17, 2024
I have Panasonic workio DP 3030 i need driver for windows 8.1 or 10 from panasonic
There is no driver for 8.1 or 10. The support stopped in 2007.
11/23/2023 8:56:31 PM • Panasonic... • Answered on Nov 23, 2023
Panasonic DP-C265 showing E05-01 error as soon as it is turned on.
See Error Code List in Service Manual of machine. E05-01 is Interlock Switch Failure. Panasonic DP-C405 Service Handbook (Page 339 of 808) ' ManualsLib
11/12/2023 12:21:33 PM • Panasonic... • Answered on Nov 12, 2023
Panasonic toughbook cf-54 has password and usb not boot need password removed. cmos battery removal does not work.
only Panasonic.com can clear BIOS admin PW.. not legal here.
8/16/2023 5:52:21 PM • Panasonic... • Answered on Aug 16, 2023
Panasonic Lumix FZ28 digital camera drains battery.
I would send it in for repair. If there are 3 contact pins when there should be 4, you will need that part that holds the pins. It is unusual to have a Service manual for cameras, but here it is and shows disassembly. https://www.google.com/search?q=panasonic+lumix+fz28+repair+manual ..
7/7/2023 7:02:32 PM • Panasonic... • Answered on Jul 07, 2023
Panasonic cf-19 Enter key not working
  • Fn is locked (pressed-down) until you press another key. Use this when pressing difficult key combinations. • Popup menu icon on/off Start up the Hotkey Settings. Click [start] - [All Programs] - [Panasonic] - [Hotkey Settings]. Make the settings. [Use Fn key lock] When using an Fn key combination Press Fn once.
6/16/2023 9:14:01 AM • Panasonic... • Answered on Jun 16, 2023
Panasonic Evo54 tv old tube tv The +B voltage to line output transistor is only 45volts Plz help Red light is on and not switching on
The usual cause is leaky line output stage or transformer. Lift the line output transistor out and see if the voltage rises. If it does, scrap the TV as it is totally obsolete. If it doesn't, repair the power supply, if you can source the obsolete parts.
5/26/2023 3:15:58 AM • Panasonic... • Answered on May 26, 2023
Panasonic CF-19KHRAG2M Rugged Laptop Computer. I need a component diagram please.
Question edited for clarity, full 'make model (what it is)'. Question moved from Television and Video category. It appears you are working on the Serial Port https://www.manualslib.com/manual/304435/Panasonic-Toughbook-Cf-19khrag2m.html?page=72&term=GPS&selected=2#manual Service Manual for CF-19CHBAXBM may be close enough. https://www.manualslib.com/manual/553265/Panasonic-Toughbook-Cf-19chbaxbm.html ..
5/19/2023 4:14:01 PM • Panasonic... • Answered on May 19, 2023
In South Africa need codes for panasonic tv. I have goldstone gs40 remote
All the codes are here https://codesforuniversalremotes.com/remote-control-codes-for-panasonic-tvs/ But..... Universal Remotes? No! What is a Facsimile Remote? Your television or other device remote control fails and you think "I'll have to get a Universal Remote". In reality, no one buys universal remotes these days. They are so far back in the 1980s! You buy a 'facsimile remote' which is exactly the same as the original and requires no programming. Very often they are the same shape and the same button layout, so there is no learning transition. Google; make model (of television) replacement remote You will find somewhere like this https://www.remotecontrols.com/ or https://www.remotes.com/ For those that still want universal remote codes, the make of the universal remote is irrelevant, you only need the television make, as the codes are universal by maker. This link will find you the best websites for codes. https://www.google.com/search?q=universal+remote+codes .. Posted by ADMIN... on May 03, 2022
4/15/2023 6:20:47 PM • Panasonic... • Answered on Apr 15, 2023
My Panasonic TV model no: TH-32D310Q Green light is blinking
A blinking green light on your Panasonic TH-32D310Q TV typically indicates an issue with the TV's power supply. Here are a few steps you can try to resolve the issue:
Unplug the TV from the power outlet and wait for at least 5 minutes. Then, plug it back in and see if the green light stops blinking.
Check the power cord and make sure it is securely plugged into both the TV and the power outlet. If the cord is loose, try tightening it or using a different power outlet.
Check the TV's manual or website to see if there are any troubleshooting steps you can take to resolve the issue.
If none of these steps work, it may be a more serious issue with the TV's power supply or internal components. In this case, you may need to contact Panasonic South Africa for assistance or bring the TV to a professional repair shop.
4/1/2023 6:12:39 PM • Panasonic... • Answered on Apr 01, 2023
Panasonic KX 7730 error in the right upper with led right and message appear on screen "Mem. Msg. Escaurita" after "Urb. Non. Assegn.
The likely cause of this message is a defective memory card or a corrupt file on it. Try replacing the memory card or reformatting it, and then restarting the machine. If that does not resolve the issue, contact the manufacturer for assistance.
2/23/2023 12:49:46 PM • Panasonic... • Answered on Feb 23, 2023
2answers
Panasonic cn-mw100d will not turn on but power is coming to unit
The Panasonic CN-MW100D is a portable navigation device. If it's not turning on even though power is coming to the unit, it could be caused by a few different things.
  • First, check that the power cord is securely plugged into both the device and the power source.
  • Second, check the battery level, if the device has a battery, if the battery is dead, replace the battery or charge it.
  • Third, check the fuse, if the fuse is blown, replace the fuse.
  • Fourth, try doing a hard reset by holding down the power button for 10 seconds.
  • If none of the above steps resolve the issue, then the problem may be with the internal hardware of the device and it may need to be repaired or replaced.
1/31/2023 8:29:42 PM • Panasonic... • Answered on Jan 31, 2023
Panasonic Toughbook CF-19 do any use a cooling fan?
Yes, they all do, otherwise the processor would fry in 2 minutes of use.
12/31/2022 1:10:19 AM • Panasonic... • Answered on Dec 31, 2022
Need a manual on operating a Panasonic R40A inverter air conditioner
It should be one of these. It looks like 'R40A' might be the refrigerant gas in it. https://www.google.com/search?q=Panasonic+%22R40A%22+inverter+air+conditioner+manual A Manual that Google thinks is it. https://docplayer.net/21544217-Operating-instructions.html ..
12/31/2022 1:07:47 AM • Panasonic... • Answered on Dec 31, 2022
Panasonic (BBHGW700A) Wireless Router Logo
Popular Tags
5 questions posted
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Computers & Internet
Most Popular Question
access address
  • Computers & Internet
