20 Most Recent Maytag LSG7806A Front Load Stacked Washer / Dryer Questions & Answers
Dryer motor hums but wont run
compassator
1/18/2013 8:06:32 AM • Maytag LSG7806A... • Answered on Jan 18, 2013
Washer keeps blowing fuses
Do you mean the houses circuit breaker? If so, WHEN in the cycle does it blow the circuit breaker? WHEN it trips will tell you what to look at. I.E. If the circuit breaker trips during the fill cycle then it would be the walter inlet valve or the timer in the control panel; if it trips as soon as it is in the agitator cycle - then the motor or transmission; if it trips in the spin cycle - then the drain pump or transmission or control panel.
10/3/2011 8:46:33 PM • Maytag LSG7806A... • Answered on Oct 03, 2011
LSG 1000 wisher will not
As a recap ,
You have a lsg 1000 washer and dryer (stacked unit)
You can wash and it goes through first cycle fine, meaning it will fill water, agitate and then spins and dis guards dirty water. BUT when it goes to put fresh water back into fill and do final rinse it, trickles out and almost sounds like its trying , but then it stops. Then you said you have to manually filled it by starting first cycle over and run through it to rinse clothes and have it spin to finish process. My advice and trouble shooting is the problem lies in the electronics. You said the whole control panel is one unit and is electronic.I believe it is in the electronic panel, and they only sell these as a unit. But I also suggested to try and see if maybe just maybe the converter is working proper, that is where it triggers, from one cycle to the other. However, i believe it still is in the electronic panel not working proper to switch to next cycle. I wish I could help you more over the phone, but when a electronic panel goes out or partially goes out, it normally has to be replaced, and like you said it has been running fine for 26 years, so you still i believer are a head of the game when it comes to getting your moneys worth for this unit last thus far that long. If any thing else I can help you with, feel free to respond, and I will do my best. Thank, Mike from fixya
7/2/2011 12:23:22 AM • Maytag LSG7806A... • Answered on Jul 02, 2011
Gas comes on for 5
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
5/10/2011 10:39:46 PM • Maytag LSG7806A... • Answered on May 10, 2011
My maytag Lsg 7806AAE stacked
Your lid switch is bad.
Have the lid switch replaced.
4/10/2011 9:27:57 PM • Maytag LSG7806A... • Answered on Apr 10, 2011
Maytag LSG 7806 Electric Dryer doesn't heat up how
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
4/2/2011 8:50:56 PM • Maytag LSG7806A... • Answered on Apr 02, 2011
I think I have to replace the blower wheel in my
Why do you think you need to replace the blower wheel assembly? If it is not drying completely make sure the ducting is clean and free from obstructions. If the dryer is not getting hot you may need to check the three thermostats or the gas valve and igniter. You can order parts from Appliancepartspros.com, which are in stock. If one of the thermostats are defective the dryer will not heat up. You need to use an ohm meter and a heat gun to test the thermostats. If the thermostats are good see if the igniter has voltage to it and is sparking. If it does you need to make sure the gas valve is functioning.
The advantage of the stackable unit is the compact size and lower total cost. The disadvantage is the small tub and drum limiting the size of loads you can run. I also think the larger units do a better job of cleaning if you have the space and funds.
Can you repair it yourself? If you have the knowledge of how to use a Volt/Ohm Meter and some mechanical skills, I think you can repair it yourself. Keep in mind you need to fix the cause of the problem before you fix the problem, or you will have the same failure again (make sure you have good air flow in your ducting). Most appliance parts stores will not take back electronic parts once you have opened or installed them. Therefore, you need to identify the part is defective before replacing it. Some appliance parts stores will test the part for you.
2/23/2011 5:51:33 PM • Maytag LSG7806A... • Answered on Feb 23, 2011
Top load stacked washer, won't pull water into machine, just
check hoses are not kinked /filter a the fill hose solonoid valve is clear if valve is okay should work...
12/3/2010 12:33:24 AM • Maytag LSG7806A... • Answered on Dec 03, 2010
Fills with water but does not agitate
Sounds like you have a problem with the lid switch. Here is a link to the part.
http://www.appliancepartspros.com/part_details.aspx?part_id=4008524
11/21/2010 4:14:08 AM • Maytag LSG7806A... • Answered on Nov 21, 2010
2answers
Hi maytag lse7806gge in order to pass
Please check the bellow link related to your issue:-
http://www.ehow.com/how_5592752_remove-maytag-washer-wash-tub.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
10/8/2010 12:49:52 AM • Maytag LSG7806A... • Answered on Oct 08, 2010
My maytag dryer was making a loud screeching noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgsghs
9/29/2010 11:05:20 PM • Maytag LSG7806A... • Answered on Sep 29, 2010
No water anytime. tried replacing
Hi.
The door switch can be tested by jumping its contacts. Moreover, if problem was the door switch the machine won't cycle.
Rather then being the door switch I think that the problem is the pressure switch. The pressure switch detects the water level. It stops voltage to inlet valve and send the signal to advance to spin when drain is complete and there is no water.
Before replacing the pressure switch test the inlet valve. The inlet valve can be tested reading Ohms at its terminals. If it reads infinity, then the valve solenoid has blown, and the valve will not open.
Here all parts and diagrams for your model: LSG7806ABQ
Regards.
Ginko.
6/25/2010 6:28:43 AM • Maytag LSG7806A... • Answered on Jun 25, 2010
3answers
The washing machine will not
Hello. Your problem most likely lies in one of two areas:
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly. Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor. J.
6/9/2010 1:26:39 AM • Maytag LSG7806A... • Answered on Jun 09, 2010
MAYTAG AUTO DRYER
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
6/2/2010 1:48:47 AM • Maytag LSG7806A... • Answered on Jun 02, 2010
Maytag LSG7806A Front Load Stacked Washer / Dryer Logo
49 questions posted
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
fills water but not agitate
  • Washing Machines
