20 Most Recent
3Com NBX 1102 PE Charcoal Phone 3C10281PE 1102PE Questions & Answers
Voicemail in use message
Reboot the phone system (through the browser) and this should take care of it. There are limited voicemail ports and sometimes they get put on hold and can't be released. I have seen it a lot. some versions of software can clear this but a reboot will take care of it.
11/11/2013 11:49:24 PM •
3Com NBX...
Answered
on Nov 11, 2013
I have AVI Video and it only plays sound
Ok it is may be do you to system is old needs up to date , so that the video may not have downloaded completely from the source web portal. The media player present in your handset is outdated.
Db9 rj45 pinout
Here is the standard pinout for a console port on a router to seriel port for computers
HI,
I have two 3com
I don't know anything about these units, nor do I have time to source any docs for you, but maybe you can try connecting a PC directly to the port your patch panel is connecting the the switch from, you can at least see if that port is working.
My next and only other suggestion is to invest in a "LAN cable tester". In my area, you can find cheap ones for U$20.
The tester will allow you to check connectivity between any two ports, and allows you to test both patch links and individual CAT5/6 cables.
Facebook recovery
notify the police dept / person handling the case and let them know about the face book information
