20 Most Recent
Maytag MDG9206 Dryer Questions & Answers
Gas dryer just won't start
I would replace the door switch since that was the start of your problem. I seriuos dobt two items went bad at one time
MY DRYER WILL NOT GET HOT. I TOOK THE FRONT COVER
Hello, Your problem is going to be with light sensor. This is mounted on the side of the burner tube. To make sure this is the problem,pull off the wires and with a ohms meter test the terminals on the flame sensor. They should read infinite...if you get no reading replace the sensor.
If the flame sensor reads infinite then your problem is with the ig-niter. Even though it glows it has to draw 3.5 amps to open the gas valve. If it's glowing orange it's bad it should be glowing yellow. If you have any other questions of concerns please feel free to comment again. Mike
When the dryer is running it make a squealing
Sounds like a Frigidaire. Is that right? If so then it will be one of 2 things...the most likely thing is the bearing in the back behind the drum or the glides that the drum rides on in the front.
Noise in dryer
Does the drum turn smoothly, or does it bounce around? If it bounces, it could be the bearings in the drum wheels going out. The wheels would need to be replaced ($20 on up).
Timer stopped running, no heat
the valve body is the problem there is a one way valve inside it if thois fails the gas will not flow to your burner. this is a prevention feature it's design is to keep back pressure to insure a flame doesn't travel back through to the source and cause an explosion.the valve body will have an intergrated regulater so replace the whole valve assembly and it should take care of the problem
Dryer makes banging noise
basscat, you first remove the door by removing the screws from the hinges. The door will lift up a litte and pull off. Next remove the spacers on the other side. Now the front panel will pull out from the top. There will be two 1/4 inch screws with latches on each side of the frame, remove these and the top will lift up. Now by holding the door switch and starting the dryer, you will be able to see what is banging. Once you determine that, you can remove the bulk-head, should be 4 screws, be sure to unplug the door switch. Unfasten the belt, remember the configuration and remove the drum. You are now able to get at the insides. Catriver..post back.
Where is the pilot light on a Maytag dryer
what is the model number? free standing pilots have been gone for several years. Google your model number and include parts.
This will give you sites that sell parts.
You most likely have and hot surface ignitor.
What is the electrical capacity of Maytag MDG9700BWW?
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=the+electrical+capacity+of+Maytag+MDG9700BWW%3F
Then check related searches
MOTOR: 1/4HP,120 volt,60 Hz,single-phase,thermally protected against overload,auto-reset. EXHAUST:Use a minimum of 4"(10.2 cm) diameter rigid aluminum or galvanized steel duct. Never use plastic,nonmetal or combustible duct. HEAT SOURCE/ELECTRICAL REQUIREMENTS: Electric model- 5,300 watt nichrome helix coil; 240 volt,AC,60 Hz; 30 amp fuse. Gas model-Single port burner with automatic electric ignition; 22,000 BTU/hr. 15 amp fuse. Self-adjusting valve automatically compensates for variation in gas pressure. WEIGHTS (Crated/Uncrated):
What dose it mean F07 Maytag dryer
The F70 indicates a communication error code between the main control on the top left and the user interface on the front. Unplug the machine and remove the top. Check the connection on the board in the white plastic housing on the top left. Next check the connections on the board on the front.
