20 Most Recent
Faberware 10-22 Cup Coffee Urn Questions & Answers
It seems to be perking correctly but stops and
Your pot needs a keep warm element. the main element works ( perks and perks) The thermostat works ( it turns the main element on and off.) The pot goes on and off because the water is getting cold
The problem is the keep warm element. The reason, your pot
perk's and it gets hot near the thermo, the thermo turns off the main element.
The keep warm element is not on so after a small amount of time the water cools
and the thermo turns the main element back on again, thus making the water hot.
The K W element is supposed to be on all the time the pot is plugged in, it is
instrumental in perking the first brew making it really hot, the thermo turns
off the main element and the K W element keeps the water hot. The K M element
is very a easy fix, it is the small looking white rope that runs around the
bottom of the pot. Thanks
and please ask if you need more help.
Go to repairshack.com for the part. Ron
The first problem we noticed is the coffee is not
Hi, The problem is the keep warm element. The reason, your pot perc's and it gets hot near the thermo, the thermo turns off the main element. The keep warm element is not on so after a small amount of time the water cools and the thermo turns the main element back on again, thus making the water hot. The K W element is supposed to be on all the time the pot is plugged in, it is instrumental in perking the first brew making it really hot, the thermo turns off the main element and the K W element keeps the water hot. The K M element is very a easy fix. Thanks and please ask if you need more help. Ron For the part go to repairshack.com
I believe the heating unit is burnt out. where
Hi. Your heating element is NOT burnt out.Since the unit is almost new, I would say someone left it on and the water evaporated and the safty fuse poped . It is a very easy fix, just take the bottom off and you will see the problem. Good luck bobbyone
Re: Farberware Model FSU-122.
Hi Jerry. It is the fuse. This fuse does not look like any fuse we are used to seeing. Very easy fix. the fuse looks like a 2-4" long piece of flat copper about 1/2" wide with a samll drop of solder in the middle. I sell the parts on eBay under ron622c, if you cant find one. Good luck. Ron
Farberware Coffee Urn won't make coffee
Be sure that the washer at the bottom of the pump stem remains loose.
If coffee grounds lodge in this area, remove under running water or with
a wooden tooth pick. Dan
10-22 urn
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
