20 Most Recent Canon L120 Fax Laser Printer Questions & Answers
LOUD SOUND WHEN SENDING FAX
There are 4 volume controls to access them press MENU.
You should see “MACHINE SETTING?” if not use the SET arrows to scroll through the different menus, stop when you see “MACHINE SETTING?” Now press the SET button.
Now use the up & down arrows to get to
Buzzer Volume = that the machine beeps
SET
Key volume = the tone that sounds when you press keys on the control pad
SET
Alarm volume = the alarm if something happens.
SET
Line volume = sets the level you hear at the fax is actively transferring a fax.
If you want to change any of the settings, press the up or down arrows to the level you like best and press SET if you don’t what to change that item just press SET. When you have adjusted all levels the way you want them press STOP and the levels will be remembered.
The most annoying sound to most people in the Line Volume. I have known people that like it as quiet as posable in thier work, but the problem is if you turn down the ALARM you won’t know when there is a problem. Many people like a little line volume so that they hear when they dial into a busy phone line, or if someone picks up the shared voice line.
7/28/2018 12:55:13 AM • Canon L120 Fax... • Answered on Jul 28, 2018
Dirty print on printed or incoming fax
I think is a cartridge problem, try to change it.
It's possible the drum to be worn. For a precise response, i need a picture with an printed page.
All the best !
12/1/2017 6:42:59 AM • Canon L120 Fax... • Answered on Dec 01, 2017
How do i clean a memory full
setting.... memory .... reset Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
8/14/2014 7:57:36 AM • Canon L120 Fax... • Answered on Aug 14, 2014
Can,t send fax
there is any message on diplay
2/17/2014 5:28:53 PM • Canon L120 Fax... • Answered on Feb 17, 2014
2answers
Storing FAX numbers in Canon FAX-L100
Hi - You can download the manual from the link underlined in blue below:
FAX-L100
See page 4-6:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
1/21/2014 7:30:12 PM • Canon L120 Fax... • Answered on Jan 21, 2014
What happen my canon fax L100 not sending and resiving
I would look to make sure that the phone line is installed in the LINE port and not the handset....
1/13/2014 8:49:07 PM • Canon L120 Fax... • Answered on Jan 13, 2014
0answers
0answers
0answers
Canon L120 - What does this error message mean?
Check Scan Platform, means: The scanning platform is dirty, or not set into scanning position. Solution Clean the scanning area, or lift the scanning platform into place.
11/29/2011 2:37:09 PM • Canon L120 Fax... • Answered on Nov 29, 2011
How do i receive a
under user mode, choose data registration, report settings and under TX report set YES. Then after each fax you get transmission report with image of document you've sent.
8/4/2011 8:42:20 AM • Canon L120 Fax... • Answered on Aug 04, 2011
Memory is full. How do I print RX and then delete
Hope this helps.
1.) Press (system monitor) until <Fax Monitor> is displayed.
2.) Press - or + to select <2.TX/RX Transmission)->Press [set]
3.) Use the numeric buttons to select the transmission numbers of the fax job you want to delete-->Press [set]
4.) If you want to delete the fax job press [-] for <YES>
Regards
7/29/2011 11:19:11 AM • Canon L120 Fax... • Answered on Jul 29, 2011
Canon L120 Fax Laser Printer Logo
95 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
receive
  • Office Equipment & Supplies
