20 Most Recent
Canon imageRUNNER 2020 All-In-One Laser Printer Questions & Answers
Can it scan?
OK, you should have canon driver/software cd.On that CD you will find Scan Gear, after installation, open Scan gear and "discover" the ir2020.( copier must be in scan mode) then press select.
Open the word or similar on your pc that is connected with USB to copier.Under tab insert chose the insert from scaner or camera, chose scan gear and custom insert.
5/5/2012 11:30:05 AM •
Canon...
Answered
on May 05, 2012
I have started getting streaks on Image Runner 2020
Try to print something, if there is any streaks?If no the problem is in copy glass (dadf or platen glass).
If there is streaks on print also,it could be the drum unit ( pull the drum unit out and see if on drum surface is any black streaks), fixing film is worn out, and in the worst case you have problem with toner unit ( on toner unit you have current leackage ) and you need (in best case) clean the contacts on toner unit, and in more expencive case tochange the toner unit.
3/2/2010 4:54:16 PM •
Canon...
Answered
on Mar 02, 2010
Canon 2020i - Copies displaced using autofeed
Im not very sure but i think it goes something like this:
Under service mode *28*, and then numeric parameters, under no.41 try to set value on 0 (but emember value before if it isnot that, so that you can enter it back) if that does not help call back and I will check it little beter.
2/15/2010 5:33:22 PM •
Canon...
Answered
on Feb 15, 2010
Scan document to pdf format
you have to set up on the machine to scan to SMB. you then creat a folder in your c drive to recieve the scaned documents the folder needs to be a shared folder and you have the option to recieve it im PDF format.
let me know if that helps you out.
2/11/2009 5:36:58 PM •
Canon...
Answered
on Feb 11, 2009
