20 Most Recent IBM IntelliStation Z Pro 6221 PC Desktop Questions & Answers
Iam having IBM 6221 13A
you did not say dual port GPU card nor using 2x GPU cards. so must be DAISY CHAINED Display card, there, NOT TOLD IT. on all PCs on earth , (NO OS told at all why?) the correct software drivers for the GPU card must be loaded from the card makers site if no card then from Lenovo. yes horz = DP? daisy chained. mon to mon link. you meant IntelliStation Z Pro Type 6221 (made 2004, 14 years ago) that>? nobody knows what is inside any desktop (added) for sure GPU cards 12 makers, + and vast models. if all IBM is it? the card choices are listed in the free IBM manual Video adapter: Accelerated graphics port (AGP) Pro 50 video with one of the following: v Matrox Millennium G450 (DVI-I) 4X with 32 MB double-data-rate (DDR) synchronous dynamic random access memory (SDRAM) video memory and a single DVI-I or dual analog connectors (or dual VGA monitor capability with the pigtail cable that came with the system) v NVIDIA Quadro4 NVS 280 (LFH-60), AGP 8X, with 64 MB DDR SDRAM video memory and dual analog connectors (or dual digital monitor capability with the purchase of an additional pigtail cable) v NVIDIA Quadro4 980XGL (DVI-I), AGP 8X, with 128 MB DDR SDRAM video memory and dual DVI-I connectors v NVIDIA Quadro FX 1000 (DVI-I), AGP 8X, with 128 MB DDR2 SDRAM video memory with dual DVI-I connectors v NVIDIA Quadro FX 1100 (DVI-I), AGP 8X, with 128 MB DDR SDRAM video memory with dual DVI-I connecctors v NVIDIA Quadro FX 3000 (DVI-I), AGP 8X, with 256 MB DDR SDRAM video memory with dual DVI-I connectors v 3Dlabs Wildcat4 7110 (DVI-I), AGP 8X, with 128 MB texture buffer DDR SDRAM video memory and 128 MB frame buffer video memory, and dual DVI-I connectors. only Display port allows daisy chaining monitors but there is no such card from IBM in 2004 worst of all AGP is dead technology. how you get DP here? we can not see back of your PC nor what is inside and desktops can be expanded greatly , no limits. really. if savvy worst of all this relic has not one, PCI-express slot. so only old relic cards fit. free https://www.manualslib.com/manual/755517/Ibm-Intellistation-Z-Pro-6221.html?page=25&term=pci&selected=1#manual good luck
1/18/2022 4:18:22 PM • IBM... • Answered on Jan 18, 2022
3answers
Post codes
Open your CPU cabinet. You see there RAM chip (DDR or SD )Dissconnect it from Motherboard. Clean it and if two chips are there alternate there positions otherwise connect it as it is. It wll solve your problem
8/26/2015 10:14:53 AM • IBM... • Answered on Aug 26, 2015
2answers
With a IBM 6223 can I mix sata and scsi drives in
Yes. you can use any mixture of different interfaces a PC. As long as you have the appropriate controller interface to plug the drive into, and your power supply is big enough to support the drive(s) you're using, there should not be a problem.
The only caveat is that if you want to boot from a drive type that is not part of the PC bios, this may not work.
Such as if the bios is so old that it only has IDE and you plug in a SATA or SCSI adapter, it may take some fiddling to make it boot properly. Many interface adapters have their own bios, and sometimes things are not as compatible as they should be.
11/26/2014 4:22:52 PM • IBM... • Answered on Nov 26, 2014
2answers
I have an ibm intellistation z pro. Workstation have 2 scsi, 2 ide and 2 sata. I have setup 01 scsi driver and setup win server 2008. When i setup sata raid 0 or 1. The win boot fail and requied cd to
Does your RAID SATA have a boot sector? Sounds like your trying to boot from a non bootable configured RAID.
11/25/2014 2:27:37 PM • IBM... • Answered on Nov 25, 2014
I have a IBM Intellistation Z Pro 6221 and it just shut down and has no power at all. I have replaced the power supply and still it will not start. Any ideas as to what could be my problem?
Hello..Flow instruction:-1> Check you power connector it is proper connect or not.2> if you are change SMPS power supply. check you power cable connect in mother board.3> if not coming power then change you power supply. because this power supply not supported. 4> And finally check all power connection point. if any problem then contact best technician.Thanks..
2/6/2013 6:38:35 PM • IBM... • Answered on Feb 06, 2013
2answers
Hi, I've got an IBM Intellistation Z Pro type 6221
Check their site. IBM Support
7/27/2012 5:52:18 PM • IBM... • Answered on Jul 27, 2012
Hi..just tried an install of
If this is your card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102829
It has a 2.0 x 16 slot requirement that may not be compatible with your system. If this is your prior card:
http://www.overstock.com/Electronics/Nvidia-980XGL-128MB-Quadro4-DVI-VCQ4980XGL-Video-Card-Refurbished/5539014/product.html
It is AGP 8x, which i a totlally different setup. I looked up your system and it has AGP 8X slot:
http://www.bing.com/shopping/ibm-intellistation-z-pro-6221-xeon-2-8-ghz/specs/71BB88F57E2979DCBF33?q=ibm+z+pro+6221&lpq=ibm%20z%20pro%206221&FORM=HURE
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125281
It would work, providing you have 400w power supply and a 6 pin connector to hook up.
The only way I can clarify what you've got and whether it's actually compatible, I need the make and model number of the card you have. You can see there are alot of different options.
Note: after looking again at the specs for you system, it comes with a 425w power supply. If you have your case open look at your power supply and it should say on it what the supply is.
Dave
6/17/2011 7:14:43 PM • IBM... • Answered on Jun 17, 2011
0answers
Upgrade Intellistation Z Pro 6121 w11 to 64bit Xeon Processors
It helps if you give the right specification - the W11 is the 6221, not the non-existent 6121.
You have 2 x 2.4 Xeon in a Socket 604 package. The only CPUs these could be are the Tigerton - it certainly does support 64-bit operation, as well as VT.
You have little choice in processors - Tulsa, Tigerton and Dunnington.
The Tigerton is a little ripper! 2 x 4MB on-die cache, 1066 internal FSB, wide voltage range and low power consumption (80W).
http://ark.intel.com/Product.aspx?id=30779
You have a 4 processor 64-bit box - if it isn't poweful enough for you (and I can't see why - I run 50 concurrent VM users on less), you can only go to the 2.93 Tigerton as an upgrade. The other CPUs have more horsepower, less torque!
Don't get hung up on processor speed - for 64-bit big cache rules.
1/29/2011 3:41:08 AM • IBM... • Answered on Jan 29, 2011
I have IBM Intellistation Z
You need a floppydisk including the Driver for the SCSI or Sata drive - Depending which HD You are using.
If the controller is in motherboard You will find the driver from motherboard webpages.
If it's a separate controller card - You will find it from it's web pages.
XP doesn't support too well sata if it's not the XP SP3 version media.
You may need to change the sata to compatibility IDE mode to get it up and running.
1/6/2011 11:36:32 AM • IBM... • Answered on Jan 06, 2011
My system misses audio drives
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, Drivers and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
12/15/2010 7:56:16 PM • IBM... • Answered on Dec 15, 2010
2answers
My IBM Z pro intelstation
hope eng uk
Please you will open the cabinet and follow the instruction.http://www.ehow.com/how_895_install-ram.html
Please you will install a new RAM .Or you will clean the ram by eraser or DVD cleaner and fit it again.
12/4/2010 2:57:21 PM • IBM... • Answered on Dec 04, 2010
I recently installed Win7 on IBM intellistation
Did you try to set your BiOS to DEFAULT?
11/6/2010 7:23:21 PM • IBM... • Answered on Nov 06, 2010
I need a network driver
Please follow this link for your Ethernet Driver from IBM:
http://www-947.ibm.com/support/entry/portal/docdisplay?brand=5000008&lndocid=MIGR-5079975
I beleive you need the bottom one (intc_dd_nic_15.1_windows_32-64.exe)
Download it, and run this .exe file.
This support's ALL IBM systems.
Hope this helps, and please don't forget to rate ^^, Thanks!
10/7/2010 5:42:03 PM • IBM... • Answered on Oct 07, 2010
When I power up the
This is one of my favourite and very easy to answer questions.
The CMOS battery is dead OR if the computer has been moved or anyone has been inside then double check that the CMOS clear jumper is in the correct position AND that the battery is seated correctly.
If the jumper is correct and the battery is seated then remove the battery and take it to almost any radio shack, The source or goo watch shop or even walmart for a replacement
TAKE NOTE OF THE POLARITY when removing it
Bob
8/25/2010 12:34:44 PM • IBM... • Answered on Aug 25, 2010
No sound no vga
install drivers from here-
http://www-947.ibm.com/systems/support/supportsite.wss/selectproduct?taskind=2&brandind=5000004&familyind=5050008&typeind=5110912&modelind=0&osind=0&psid=bm&continue.x=1&matrix=Y
//javaftper
8/1/2010 5:31:53 PM • IBM... • Answered on Aug 01, 2010
I have an Intellistation Z Pro 6221, WinXP OS, wit...
let windows determine your virtual memory
6/1/2010 10:14:14 PM • IBM... • Answered on Jun 01, 2010
IBM IntelliStation Z Pro 6221 PC Desktop Logo
Popular Tags
56 questions posted
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Computers & Internet
Most Popular Question
ibm intellistation z pro 6221 just shut
  • Computers & Internet
