20 Most Recent IBM 11P836402 for ThinkPad R40 Monitor Questions & Answers
I have a hp, i
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
2/23/2011 4:24:22 AM • IBM 11P836402... • Answered on Feb 23, 2011
My thinkpad r40 has not display on the screen.
There are a few options as far as what could be going wrong but unfortunately whatever it is, it won't be good. The options are: video card (probably onoboard, if this is the issue the whole motherboard will need replacement), driver board for the LCD display (cheaper fix) or the LCD itself (probably not the issue). The only way to know for sure is to take it in to a place that fixes laptops and have them look at it. They can order the part you need and install it for you or at least check it out and give you a quote. If it's the motherboard it would be better just to buy another laptop instead since it might cost up to $300.
There's a very low chance it could be driver software related but this could only be the case if it does it ONLY after starting windows and during the welcome screen. If it does it during that black screen with white writing when it boots up, then it's hardware since at that point no drivers are loaded.
Hope it helps.
1/18/2011 6:57:20 PM • IBM 11P836402... • Answered on Jan 18, 2011
Need to restore facory settings on ibm r40
Hi, During the boot at the THINKPAD SCREEN press the Thinkvantage key ( Blue button ) it will launch rescue and recovery and allow you to reboot factory. This only works if you did not corrupted/deleted the rescue and recovery hidden partition on the HDD.
Otherwise you will need the rescue and recovery CD to proceed. IBM/Lenovo support should be able to provide you the CD.
thanks and have a nice day J-
6/8/2010 1:58:48 PM • IBM 11P836402... • Answered on Jun 08, 2010
A dark blue ink splodge has appeared on my screen!
Usually we can see these type of spots, if we place any magnetic field next to a CRT monitor. Try removing if any speakers or its power adapters or any radiating devices near to the monitor. It will get ok after a while.
If still the problem persists contact a service center.
Please come back and rate my solution if this turns helpful for you or also if you need more clarification. Thnx
4/4/2010 7:44:06 AM • IBM 11P836402... • Answered on Apr 04, 2010
IBM R40 Screen Problems
I think you have an inverter board thats just about dead. It's located in the screens plastic housing at the bottom of the screen just above the keyboard. It's about 4 inches long and a half inch wide.There's just one little cable connecting it. But you have to take your screen apart to get to it. It's easy to replace and relatively inexpensive but it does require a little disassembly skill.
Also ,I will need the exact part number from the bottom of your laptop. There are several different R 40 models, and 2 different screen sizes.
7/24/2009 3:12:10 AM • IBM 11P836402... • Answered on Jul 24, 2009
The screen is black but the background is there it
I would try a solution of CLR and try to wipe the coffee down with a sponge. If that doesnt work I think you might need a new monitor.
Wayne
6/26/2009 8:19:45 PM • IBM 11P836402... • Answered on Jun 26, 2009
Spotting on IBM R40 TFT Screen
you can get a screen replacement cheaply on ebay/craigslist
12/11/2008 1:57:51 PM • IBM 11P836402... • Answered on Dec 11, 2008
Monitor
Try connecting another monitor first, but seem to be related to your video card.
Check the video card on your computer.
10/17/2008 6:27:52 AM • IBM 11P836402... • Answered on Oct 17, 2008
2answers
Lcd monitor streaking
The solution may be one of several things. here are my ideas in increasing severity.
1) Bad connection. Fix: tear apart the screen and check the video connection. It looks just like that when you don't have a good connection with the sync signals from the motherboard
2) Bad screen. Check video feed to external monitor. Shut down laptop. Plug in an external monitor. Start it up and the external monitor should show a good picture if the problem is a connection or a bad screen. If it's a bad screen, you will need to replace it (easy to do at home for 1/3 the cost of some outside source). Go to ifixit or instructables or repair4laptop to get ideas and walkthroughs. So, good feed to external monitor and no bad connections=bad screen... maybe.
3) bad video card. Replace motherboard = $$$. this is more difficult to do at home. If the external monitor shows the same streaky picture, you're pretty much guaranteed that you will have to replace the motherboard.
try pushing on various parts of the computer to see about bad connections, usually two thirds to three quarters of the way up the back of the screen is the connection and somewhere under the keyboard is the video card. don't press too hard, but see if anything's different when you try it. Good luck.
9/2/2008 11:16:21 PM • IBM 11P836402... • Answered on Sep 02, 2008
3answers
Dell monitor
if it is not adjustable then there is a problem in horl oscillator section in monitor it is a common problem & not a major one. if you are not tech person call tech person to fix it. good luck.
3/26/2008 6:20:14 PM • IBM 11P836402... • Answered on Mar 26, 2008
Display problem
I beleive its the videocard thats overheated, update your graphic card.
11/4/2007 12:49:45 AM • IBM 11P836402... • Answered on Nov 04, 2007
2answers
Blank Screen
ccfl ( cold cathode flouroscent lamp ) is the backlit feature of the lcd panel. If you see a blank screen but do see the output on the external monitor then you sure have to take it to the hardware tech to get the inbuilt LCD panel checked. it seems to be a electronic failure. Thanks Ashish.
9/22/2007 8:54:32 AM • IBM 11P836402... • Answered on Sep 22, 2007
SyncMaster 753 DFX 17'' CRT show monochrome image
Oh vintage 386sx? In old graphics cards, there were DIP Switches to configure either to use as monchrome mode or color mode. Did you configure graphics card properly ? Moreover try using mode command to change monochrome to color.
1/5/2024 10:46:02 AM • IBM Computers &... • Answered on Jan 05, 2024
IBM wheelwriter 6 only types when I press hard to the keys. Normal typing doesn't activate key strikes. Is there a sensitivity adjustment on the wheelwriter 6?
The IBM Wheelwriter 6 typewriter does not have a user-adjustable sensitivity setting for key strikes. However, the issue you're describing might be related to the keyboard mechanism, individual key switches, or the impact solenoid. Here are some steps you can take to troubleshoot and potentially resolve the issue:
  1. Clean and Lubricate: Over time, dust, dirt, and debris can accumulate inside the typewriter, affecting key movement. Try gently cleaning the keyboard area, especially around the key switches and mechanisms. Additionally, applying a small amount of appropriate lubricant to the moving parts might help improve key movement.
  2. Key Switches: Each key has its own mechanical switch underneath. If a key requires more force than usual to activate, it could be due to a worn or dirty switch. You might need to disassemble the typewriter to access and clean the key switches.
  3. Impact Solenoid: The impact solenoid is responsible for striking the print head against the paper to make an impression. If the solenoid is weak or sticking, it could result in the behavior you're describing. Try cleaning and lubricating the solenoid. If the problem persists, the solenoid might need to be replaced.
  4. Key Flex: The flex you feel in the keyboard might be contributing to the issue. If the keyboard has any physical damage or if the flex circuit is not seated properly, it can affect key activation. Carefully inspect the keyboard area for any visible damage or misalignment.
  5. Professional Repair: If the above steps do not resolve the issue, it might be best to seek the assistance of a professional typewriter technician. They have experience with these machines and can diagnose and repair mechanical issues more accurately.
8/5/2023 4:11:23 PM • IBM Computers &... • Answered on Aug 05, 2023
2answers
I have a IBM personal computer Platinum III When I turn on my computer it starts normally but after that on my screen appears a text that says "System Error: tastiera Blocked" And after I can't continue to boot and it shows on my screen a error without a code...What should I do??
Tastiera indicated that you have a keyboard problem. Most desktops can't run without a working keyboard. (You need the keyboard connected and working during the power-on self test, POST.) Currently the motherboard can't communicate with the keyboard. What is the model number for your computer? I don't recall a Platinum III, just a Pentium III. Is it a laptop or a desktop? What type of keyboard do you have (USB or PS/2 connector) or is it the built-in one of a laptop? Are you using some sort of converter/adapter for the connections? The USB to PS/2 converter for a mouse does not work with a keyboard. There are some USB to dual PS/2 converters available. However, they don't work with with all motherboards. What OS is installed on the system? Try a different keyboard. (You should try a PS/2 keyboard if the system has PS/2 ports. If the OS is older than Windows 98 v. 2, then the USB ports are even more likely to not see the keyboard in POST.) If you use a USB keyboard, try different ports. If possible, make sure that the keyboards work on other machines. If it does, then I recommend replacing the system. The Pentium III is a ~20 year old CPU. That's certainly old enough to have major failures. I hope this helps. Cindy Wells
11/23/2022 9:54:18 PM • IBM Computers &... • Answered on Nov 23, 2022
Bios update for my older IBM 8189UNU think center
don;t do it , most brick the PC doing that millions did, just now;. why ask here and not IBM or Lenovo ,we have no bios here, not a drop.
5/21/2022 1:34:29 PM • IBM Computers &... • Answered on May 21, 2022
My desktop is IBM Thinkcentre 8143-KQ7.I have
RAN FOR 14 YEARS AND FAILED JUST NOW, NO WAY AT ALL , NO HISTORY TOLD (SAD FACE)THE COIN CELL IS DEAD. 14 YEARS OLD ALL ARE OVER 7 OR SOON.THE JUMPER IS HERE. IN THE MANUAL FOR PW RESETS. EVEN INDEXED AS SUCH.SEE CMOS CLEAR JUMPER PAGE 28THE BOOKS IS CALLED CLEARING PASSWORDhttps://www.manualslib.com/manual/645124/Ibm-Thinkcentre-8143.html?page=28&term=JUMP&selected=1#manual
5/5/2022 2:38:29 PM • IBM Computers &... • Answered on May 05, 2022
IBM System X3400 M3 7379 hangs at UEFI Partition Initialization
1: no options inside told.2: no CMOS COIN cell ever lasted 13 years, so id dead3: now BIOS is in CHAOS mode. dead battery caused,4: new coin cell,.5: reset bios to factory fresh defaults in BIOS page 1.6: set time and date in bios.7: set boot order or your boot drive or raid array based on #1 above secret.8: load Server 2012R2 is best here . or linux or what is in the list .if using raid it must be tested first the array under the raid controller. path. depends on what is there, not told.a dead server can be accessed via, IMM like my dell DRACit has page called logs to read.Id read them. (opps it flags coin dead , see?)_IMM (remove manager) , READ THE LOgs , remotely.>?? first?AND SEE LAST BOOT DEVICE./? (and what)????????????????new coin cell and ....THEN SET BIOS BOOT ORDER TO CORRECT BOOT DEVICE?got raid?1 raid or more.1 for boot?1 for data.???????????????????????????? look inside yet see what is there, even count all disks see where all connect . to what.run the raid config, some servers have raid support DVD or uSB stick to boot and manage the arrays/, but what is inside matters firstsome have upgraded LSI raid cards and that matters most if there, ? day one new had 7 cards as an option. (just with IBM alone)there are MORE. LSI makes great RAID cards, Got raid?The System x3400 M3 server supports optional spare DIMMs, memory mirroring, and RAID-0, RAID-1, and RAID-1E support standard with optional RAID-5, RAID-6, RAID-10, and RAID-50 availablemost servers like this the built in raid is weak , not allowing raid 6 mode.so that matters too if that was done day1, last time.https://lenovopress.com/tips0808#standard-specificationsthe manual is here (lenovo says EOL, zero help)https://www.ibm.com/support/pages/installation-and-users-guide-ibm-system-x3400-m3-7378-7379I anm not any kind of IBM guy. (data centers)but have Dells here, and can work them wellIMM find and read all logs carefully,most servers logs what disk drive last booted OKAY. explicitly/and how to open the case and learn what is inside first. for sure all things RAID.
5/5/2022 12:59:33 PM • IBM Computers &... • Answered on May 05, 2022
I have an old IBM ThinkPad, 300MHz, 64MB RAM, and
ANDROID 12 OR WHAT? to do what (Bluestacks games") ASK ONLY THE ANDROID DISTRIBUTOR THE ANSWER NO BUT THERE ONE INTEL CHIP ANSWER IS YES. THE PROBLEM IS NO PC TOLD OF VAST THINKPADS many ibm think pads have ibm gate arrays for chipsets that nobody supports on earth. no PC told like this R40-12345, no sub codes ether, and hopeless why not go to a read android forum and ask what PCs it runs on and then buy only those.? vast PC will not do this. read android minimum requirement first. GOOGLE HITS, MATTER https://android.stackexchange.com/questions/34958/what-are-the-minimum-hardware-specifications-for-android ASK THEM OR ON OTHER OFFICAL ANDROID FORMS. https://source.android.com/setup/build/requirements NO PC TOLD , SO WE not one clue what is inside it. zero NOT TALKING WINDOWS ANDROID EMULATORS HERE ANDROID IS FOR HAND HELD DEVICES, ONLY With some exception NOW. (newer CPU) Open source Android x86.org Android on PC. no CPU told by you nor the PC model. use it as your primary operating system or run it in a VM the tests are done by the project members and others from android-porting group.
  • Microtech e-tab Pro (2018)
  • ASUS Eee PCs/Laptops
  • Viewsonic Viewpad 10
  • Dell Inspiron Mini Duo
  • Samsung Q1U
  • Viliv S5
  • Lenovo ThinkPad x61 Tablet <<< (yOU,??? not told )
1000000 PC models 30 years, and most can not do this. all chips on the PC must be coded and most are now dead chips zero support of any kind like SIS, VIA and Nforce , all dead. and vast other sound chips and wifi and more lots more dead. there are more dead now than alive that is a fact. someone must write the drivers, not you ? https://www.android-x86.org/ that is all I can find, my wild games.
1/18/2022 6:18:47 PM • IBM Computers &... • Answered on Jan 18, 2022
Computers & Internet Logo
18 questions posted
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • IBM Computers & Internet
Most Popular Question
thinkpad r40 not display screen
  • Computers & Internet
