20 Most Recent Maytag M6P09S2ACOM Air Conditioner Questions & Answers
Runs loud when the compressor kicks in? Why?
Check vibration eliminators on the feet of the compressors, over time of running in tough conditions they wear out and cause rattling. If this does not fix the problem see below -check amp draw, if amp draw is high windings are wearing out and compressor is running harder, may need replaced - check to make sure your refrigerant charge is correct you could be slugging the compressor -find other ways to isolate compressor operations
5/29/2017 10:13:24 PM • Maytag... • Answered on May 29, 2017
2answers
My Maytag air conditioner won't turn on.
The red light on this model indicates, like a dehumidifier, that the internal condensation "tank" is full. This unit normally discharges excess humidity through the exhaust vent. When humidity is excessive the unit cannot evapoate all the moisture out the vent pipe. There is a black rubber plug in the back bottom of the unit. Get a very shallow pan that will fit under the unit and pull the plug. After it has drained completely, run the unit on fan only to continue to dry out the internals. After 30 minutes or so, switch to cool and it should run. If the unit shuts off again after about 10 to 15 minutes, you have some sort of blockage that is causing the moisture to backup and trip the sensor. You will have to take the back off the unit and remove the blockage.
3/23/2015 11:53:03 PM • Maytag... • Answered on Mar 23, 2015
0answers
Need a manual
Be the first to answer 5/27/2014 3:53:13 AM • Maytag... • Posted on May 27, 2014Be the first to answer
Need to order new air exchange tubes
GOTO www.maytag.com and click 'support'
11/5/2013 3:23:20 AM • Maytag... • Answered on Nov 05, 2013
0answers
Unit will not run. shows E1 on display.
E-1 Indoor thermostat sensor defective.
12/13/2010 4:33:38 PM • Maytag... • Answered on Dec 13, 2010
Leaking water out of bottom of air conditioner
Drain is stopped up or your drain pan has a leak.
10/13/2010 5:36:37 PM • Maytag... • Answered on Oct 13, 2010
0answers
Is there a drain or
Be the first to answer 8/14/2010 5:15:37 PM • Maytag... • Posted on Aug 14, 2010Be the first to answer
M6P09S2ACOM MAYTAG PORTABLE A/C I NEED A MANUAL
i need the manual please help me send one to me at :
1550 depew st lot E8
lakewood , CO 80214
or e-mail me at :
[email protected]
or you can call me at :
303-955-8110
7/21/2010 2:14:32 AM • Maytag... • Answered on Jul 21, 2010
Water is spilling out of the back of the unit.
the only thing to do is put the unit in a permanent place and run a drain some where.
7/18/2010 2:36:16 AM • Maytag... • Answered on Jul 18, 2010
I have a used maytag portable air conditioner
Check with a local HVAC supply house or try W.W. Grainger.
The flex hose is a pretty common thing.
7/16/2010 1:23:44 AM • Maytag... • Answered on Jul 16, 2010
Blows hot air
If your machine is an air conditioner then the little hose needs to drain condensation to the outdoors. Most of the time there is a pump that the hose is attached to inside the unit. If the overflow switch is open the compressor contactor will not operate but the fan will.
6/19/2010 4:05:56 PM • Maytag... • Answered on Jun 19, 2010
Do you ever have to refill freon ever?
These types of appliances are not constructed in a serviceable manner. It is not practical to add refrigerant, since it requires evacuating the system, installing line taps and recharging to proper charge level. This can be done, but it would cost more than a new appliance. Almost all machines containing refrigerant lose some over time making them less efficient until they quit working.
6/1/2010 2:42:28 AM • Maytag... • Answered on Jun 01, 2010
Room temp stays at 76 and will not get any colder
From what you are describing the unit is working perfectly...You just have alot of heat infiltration and the best that unit can do is 76....
If you want or need it cooler you will need to buy a larger size unit...
heatman101
5/6/2010 11:28:49 PM • Maytag... • Answered on May 06, 2010
Fan motor not functioning
probably
8/17/2009 9:44:49 PM • Maytag... • Answered on Aug 17, 2009
Besides the filter directly in the back of the
Hi, there are no inner filter to be clean, you did good job by cleaning coils at back, but you should try to clean evaporator or cooling coils, is possible you need to service it, remove it, strip it down cover all electrical parts, and give him a bath, power hose, then leave it to drain for about 2hr before putting it together, that should be done by trained mechanics, also you should check size of room, and AC b.t.u, it could be possible, your AC is not right b.t.u, you should check and make sure you have the right amount of b.t.u AC for size of room.
8/2/2009 5:14:36 AM • Maytag... • Answered on Aug 02, 2009
Maytag M6P09S2ACOM Air Conditioner Logo
30 questions posted
Top Maytag Heating & Cooling Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Heating & Cooling
Most Popular Question
m6p09s2acom maytag portable c need
  • Heating & Cooling
