20 Most Recent
Maytag M6W12W7A Air Conditioner Questions & Answers
I get a EE code
Hello
EE is a high pressure error code. The unit may be to small for the room deppending on what temp it is outside.If its over 95.f The a/c is probably overworked.
One way to solve this would be to cool down the coils outside.Spray water lightly on the outside of the unit too cool it down which will bring the pressure down also.
Can I plug in a
The 20 amp would be enough for your AC as the initial current drain will be only when the motor starts ups and will reduce to about half on running.
So provided the AC has no fault of its own the present socket can be used and spcially if the socket quality -- must not heat while the AC is running.
Can I plug in a 230V 15 amp window air into my 20
Hi, the amps would be OK, but you have to have a 230 volt outlet to plug it into, or it will not run. There is no other way to do this unless you run a 230 volt line over to the window unit. You can do this from the outside of the house. This is all you can do unless you move the a/c to where you have a 230 volt plug, and I don't think you want that. This is the only way I am sorry to say.
Sincerely,
Shastalaker7
Installation
NO. It is designed to be installed in only one direction.
