20 Most Recent Maytag 14.8 cu. ft. / 419 liter Chest Freezer MQC1557AEW Questions & Answers
Freezer is getting hot on the left, right and
check condesor fan motor
4/13/2011 2:25:08 PM • Maytag 14.8 cu.... • Answered on Apr 13, 2011
Hi, just moved. Everytime we plug in the freezer
hi 15 should do it is it aGFI braker? jim
10/9/2010 1:03:37 AM • Maytag 14.8 cu.... • Answered on Oct 09, 2010
My 5-6 yo freezer just
change the gfi its starting to fail do it soon before you damage the freezer
9/9/2010 10:22:16 PM • Maytag 14.8 cu.... • Answered on Sep 09, 2010
Kelvinator Model UF 510 caught fire on top of the
No, It is very unusual for a freezer compressor to catch fire...while they can run very warm alot they do not get that hot unless there is the failure of a couple of things at once..
heatman101
5/2/2010 7:44:40 PM • Maytag 14.8 cu.... • Answered on May 02, 2010
Moving, CA to Florida and want ot load a chest freezer on its end
You could expect internal compressor oil to flow into areas which would restrict refrigerant flow, resulting in no cooling. If you have to ship on end, make sure the compressor end is down !
6/8/2009 12:00:24 AM • Maytag 14.8 cu.... • Answered on Jun 08, 2009
Problem with Maytag Chest Freezer model MQC1557aew.
First make sure than the condensing coil in the freezer is clean of dust and dirt(it is behind the grill vent in the bottom side of the freezer where the compresor is) If it is clough brush the dirt off after you unplugit.When is clean wait a few minutes ,5, and plugg it back at the GFI outlet and see if work If still tripped the outlet you may have to replace it.
4/4/2009 7:49:46 PM • Maytag 14.8 cu.... • Answered on Apr 04, 2009
Chest freezer not getting cold after moving
IS the compressor running? If so u probably cracked a line and lost the refrigerant charge.
2/27/2009 7:32:38 PM • Maytag 14.8 cu.... • Answered on Feb 27, 2009
Maytag chest freezer mac1557aew does not get cold
This can be a number of things, one being a bad compressor/motor.
Does it run at all?
If not, the compressor needs to be looked at.
If you are handy, there may be a wiring schematic in the back to further troubleshoot.
You can trace the wiring from the thermostat to see if there is power at other components.
2/20/2008 6:01:37 PM • Maytag 14.8 cu.... • Answered on Feb 20, 2008
Where is the defrost timer located on a Maytag upright freezer model RFU200FAAW?
Most parts are obsolete, and the timer is expensive! https://www.repairclinic.com/ProductDetail/96494?page=3 Timer-Def Part Number:WP3-81329 In Stock, 1 available Note: (Series: B2) $82.10 Add to Cart 16 Defrost Heater Part Number:W11175809 In Stock Note: (Series: B2) The defrost heater keeps the cooling coils from frosting over. $71.30
10/2/2021 9:10:41 PM • Maytag Freezers • Answered on Oct 02, 2021
2answers
My maytag frezzer icebox is groaning
its the fan
1/15/2019 12:17:44 AM • Maytag Freezers • Answered on Jan 15, 2019
Refridgarator is not cooling
thermostats are usually a "on/off" switch just as a simple light switch. Ohms on a defrost timer is not very specific. It is basically a switch that turns heaters on and off while keeping the compressor off during the defrost cycle. Your thermostat may be sticking/hanging up.
8/11/2017 2:10:41 AM • Maytag Freezers • Answered on Aug 11, 2017
ICE BUILD UP IN A MAYTAG MODEL MZF34X16DW UPRIGHT FREEZER
I have had a few of these, and others of the same ilk. Your problem should be air leakage into the machine. Take a thicker piece of paper, not cardboard, and try to slide it around the gasket where the door gasket contacts the front of the freezer. The gasket should be firm enough to prevent the paper from sliding. Wherever you can move the paper, you could have a air leak. Most of these have no adjustment in the latch to tighten the door. Sometimes a new gasket will solve the problem, sometime a new door will. P.S. Twice I have tied a new freezer to a refrigerator dolly to move it and have accidentally warped the door, and they cannot be straightened. :-( God bless your efforts.
7/7/2017 6:22:49 PM • Maytag Freezers • Answered on Jul 07, 2017
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
5/2/2017 7:04:48 PM • Maytag Freezers • Answered on May 02, 2017
Maytag 14.8 cu. ft. / 419 liter Chest Freezer MQC1557AEW Logo
Popular Tags
11 questions posted
Top Maytag Freezers Experts
john h
ADMIN Andrew
ADMIN Andrew
vince
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Freezers
  • Maytag Freezers
Most Popular Question
moving ca florida want ot load chest
  • Freezers
