20 Most Recent
Maytag MDB5100A Dishwasher Questions & Answers
The panel is flashing rinse
I had the same issue and got it to reset.
heated wash, normal wash
all lights came on, I hit cancel.
Closed the door
repeated above
and it's back to normal.
Hope that helps someone.
MDB5100AWB.. dishwaher will not
Hello &
Welcome to FixYa
If the drain
pump assembly is clean and clear (located inside the bottom access panel) then
the problem is with the timer going bad and needs replacement. When the timer
goes bad it wont advance to next cycle and so the dishwasher won't run
properly, replacing the timer is recommended repair. Please get back to me if
you have any other questions.
Kevin
Water is not enter dishwasher
The problem is most likely the water inlet valve. This is a solenoid
that opens when there is power to it. It is a common problem on
dishwashers and washing machines.
They are not very expensive and are usually fairly easy to replace.
If you need more help, post a comment.
Thanks,
Tim
Upper & lower spray arms do not turn. Runs
I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not WorkingDishwasher Maintenanceheatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Maytag dishwasher, control panel is dead, has
i think you have diag your problem . your have power to the board . so the inter lock switches are ok . and no lights . if you look at the printed pc board i think yoy may be able to see that one or more soder joints have failed . best to change board ant this will correct problem. pt # 99002832 ( 123.89 ) . hope this has helped mm and thanks for using fix-ya .. mm
Dishwasher detergent does not dissolve during
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
I have tried many many dish soaps and rinse
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see
how simple it was. thanks Ronnie " - ronnieshomes
Not draining. fills, then smells
there is clog in your main drainage line, you are smelling the decay of your food, rinse off your dishes before placing them in the dishwasher
