20 Most Recent
Opti - UPS ES800C 800VA 480W 1050 JOULES AVR 6 OUTLETS RJ11 RJ45 SOFTWARE CABLE (25880) UPS System Questions & Answers
Uninterruptible Power Supply Faults
UNINTERRUPTIBLE POWER SUPPLY – FAULTS
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. Including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage of each battery may show 13 volts when tested with a multi-meter. This is a float voltage and a true indication of the battery voltage and its condition requires each battery to be tested under a load. If one battery is faulty in a set of batteries it will causes the whole battery system to fail and indicate a battery fault.
Also a faulty charging circuit will not charge the batteries and will cause a fault condition warning.
Opti UPS. The battery backup won't turn on after power out.
Question edited for clarity.
Question moved to Opti UPS.
- Larry Ng Mar 13, 2022
no model told (of vast and feature rich ) hopeless lacking this.
and worse Opti ups
is not APC, at all, so wrong forum
so wrong maker
and the model matters huge.
ask them only
random picked Thundershield, that too not told nor KVA
https://www.opti-ups.com/index.asp?SCID=...
Anonymous Mar 13, 2022
the battery is 99% cause of failures
replace it
or learn to test it ,called UPS battery bench load testing, google it and learn how.
hint it takes tools. ask.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
Is there any one here know B**** food equipment? I have question about this company?
As you are Anonymous, it would seem like this is a veiled advert to get the company name promoted.The company is in British Columbia, Canada. What is your concern? I am in Ontario and have had a 50 years career in catering.Finding them is easy, reviews are goodRahmalek "Very good service, best prices in town."Mikey "Great customer service, reasonable service fees and on time all the time."salek "Great experience working with B***** FOOD equipment. excellent customer service."..
