20 Most Recent
Intel Celeron -D 2.26Ghz Computer System PC Desktop Questions & Answers
Project IGI game shouing D3D Driver error
this is because u have disabled d3d acceleration .to enable it
1.select run from start menu
2.type dxdiag and click ok
3.then dxdiag dialogue box will appear.from it select the display tab at the top and click enable d3d option.
How to enable direct3d acceleration
CELERON processer is designed to reduce the power consumption and increase the battery life for laptop?desktops.
If you want to include direct 3d acceleration on windows 7you should give the data through HDMI port or install directX10 3D from microsoft's website. and also increase your RAM size.
thank you for giving me the chance of helping.
give your ratings please!
After changing my BIOS
Make sure it is enabled in the bios? do you get a speaker icon by your clock? also check and make sure there isn't a conflict . this is done in the properties tab on device manager. the BIOS update may have change the IRQ settings and now it is conflicting.
Hello i have an intel
if you look on the back of your p.c it should tell you the model of you p.c all you then need to do is go to the manufacturers website and look up your model and download the relevent drivers, failing that just google your p.c model
hope this helps a little bit but with out the p.c information like the brand and model type i cant help much more
I want audio drivers
go to goole and type the numbers and for the mother biord that you will see they wil direct you to the vendors website or have some to led you the disc make sure you know the name of your drives
My sound card on my
If it is on board sound then first check in bios that sound audio device is enable.
For that when you power up the computer press F1 or F2 or del or ALt+F2 to enter in bios then go to pci configuration and make sure audio is enable then save settings and exit.
If it was already enable then make sure audio driver is installed and working fine.
You can check it in device manager.
Right click on my computer icon then click on property then click on hardware->device manager then you can see all drivers list then make sure audio driver is installed.
If still same issue then uninstall audio driver from start menu->control panel->add remove programs then reinstall driver from disk.
If you haven't driver disk then download audio driver from desktop menufecturer web sites then install then it will work fine.
If you have sound card installed in PCI slot of cpu then open cpu cabinet then reconnect sound card in another pci slot on motherboard then reinstall audio driver then it will work fine.
Also make sure there is not any loose connection on sound jack and speaker cable.Make sure in control panel sound property there are not any mute sound.
Play song file in window media player and make sure sound is not mute on it. Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Whatis the procedure to start
After reformatting any computer, to receive full functionality, you need to install appropriate drivers for each device in the system. Your sound is one of these devices. You can download drivers for the HP Compaq dx7380 Microtower PC from HP's website:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3360416&taskId=135&prodTypeId=12454&prodSeriesId=3360371&lang=en&cc=us&submit=Go%20%BB
Select your supported operating system, and search for your audio drivers. If applicable, you will probably want to install other drivers as well.
