20 Most Recent
Jabra BT150 Wireless Headset Questions & Answers
How do i charge my
Use the AC adapter to charge from a power socket.
The charging socket is located at the top of the headset (the wider end). When the LED is solid blue, your headset is charging. When the solid blue LED turns off, it is fully charged.
My headset will not turn
Hello
Your bluetooth headset is powered by an internal battery. If the battery is not charged,it just won't turn on. Fully charge your battery before use.
Make sure that the power outlet you're using is working and that the cord is fitted correctly into the wall, PC or Car outlet and the Jabra Bluetooth device.
Try unplugging the Jabra Bluetooth device and see if it turns on. If so, use the Jabra Bluetooth device until the battery is completely exhausted. The next time you charge it, check that it is charging properly
If the Jabra Bluetooth device is still not charging, check what happens when you initially plug the Bluetooth device into its charger. If the light on the Bluetooth device flashes on and then off again quickly, it is likely that the battery is no longer working. Batteries cannot be replaced or covered warranty
Setting up pairing
Fully charge your Jabra BT150 and switch on by pressing the
answer/end button
Press the answer/end button and the volume up (+) button together,
to put the Jabra BT150 in pairing mode
Set your mobile phone to ?discover a Bluetooth device?
(see your phone user guide)
Press Yes or OK when asked if you want to pair the phone with
the Jabra BT150
Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK
Your phone will confi rm when pairing is complete
I cant get my jabra
Unfortunately you can't really replace the battery in that unit, once it dies it's pretty much gone. You would need to break open the case to get to the battery which of course renders the whole piece useless. On top of that a new battery would be around $15 for that style battery, and you can get a whole brand new "Samsung" bluetooth unit for $17.89 with free shipping here:
http://www.amazon.com/gp/product/B001UCELX4?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001UCELX4Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Jabra BT150
The first dude is an idiot! The battery is toast go buy a headset that isn't as old as this Jabra! I also have the issue & no didn't plug it in wrong...it only goes one way! Mine sat for a few years unused & now will not charge...You can get newer headsets pretty cheap! Look around!
Jabra BT150
DO AS THAY SAID HERE.......Press power button and the - and + volume buttons at the same time AND THEN WHEN THE BLUE LIGHT STOPS ON !!!!! GO TO YR PHONE AND SEARCH FOR THE HEADSET WHEN U HAVE FOUND IT ON YR MOBILE TIPE .........0000...... then you will be sorted
hope this helps c ya
How to clear bluetooth to
You can pair BT150 with up to four phones or other bluetooth devices.
Before you pair it with a new phone, use the bluetooth menu on the phone it is currently paired with to disconnect it.
The passkey is 0000
