20 Most Recent
Kodak EasyShare C315 Digital Camera Questions & Answers
FORMAT MEMORY CARD
After downloading any pics from the card using a card reader if necessary, go ahead and format it in the camera.
Have lost me users manual
You can view one online and/or download a PDF version from
http://www.kodak.com/global/en/service/products/ekn031109.jhtml?pq-path=3905/6839/7477
Starting button stucked
Not a lot of info to go on. If it's a mechanical problem, you might need to bring it in for professional servicing. You can try a small amount of denatured alcohol around the button to see if it cleans up any residue that might be causing the problem. Put some on a cotton swab and rub it around the perimeter of the button.
Memory Card Requires Formatting
Hey B418,
Formatting will delete all your pictures on your camera or memory card. The camera might be prompting you to format because the the camera's memory is full. To avoid losing your pictures I would connect your camera to a computer, download your images to your computer first, and then format the memory.
Sincerely,
Allan
Go Ahead. Use Us.
Internal memory card full
This camera has an internal storage capacity of 16.0 MB. That isn't much. But, it also has a slot for an SD memory card, which is capable of storing far more data than the camera's built-in memory. If you don't have one, go get a good quality, high-capacity SD card and install it in your camera according to the instructions. You should be able to store all kinds of pics and videos. But keep in mind that even the SD card has a limited amount of storage capacity, so you'll need to download the card to your computer now and again and re-initialize the card, or buy another when it gets full.
