20 Most Recent
Lexmark X3330 All-In-One InkJet Printer Questions & Answers
LEXMARK 5650 HOW TO RESET INK
HI.. TRY THIS Take a small pice of clear tape. Try covering one of the outside
vertical row of contacts at thr front of the cartridge. Re-insert it and
it shoudl "fool" the printer into thinking it is a new cartridge. It
works for my Lexmark 2600 series all in one. Good Luck.FORUM PREFERED http://www.fixyourownprinter.com/forums/printer/35235
Cant reset ink levels after refilling
you can not reset the ink levels on new lexmark cartridges
You can only use new ones
and the one that you have refill will stop working after some pages
The best printers are Hp that can be refillies with no problem
My lexmark x3330 wont print it is saying cartridge
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
I install scaner lexmark x3330 on vista64 bit but
right click on my computer icon then clcik on proeprty then hardware 0>device manager
then uninstall all usb drivers then restart the computer .
If still face problem then change usb cable.
If still same then when you power up the computer press F1 or f2 or 'del' key to enter in bios then go to advanced then usb enable usb legacy 2.0 then save settings then check.
Lines appear through pictures
Try changing your printer settings to picture/highest quality in the program also try a realignment if that hasn't been done recently... My printer is a lexmark and has a high quality setting if its not set correctly it will show lines in photos * this setting will use alot of ink typically*
It is not priting
re-instal the software of your printer and restart your computer you will soon get a better result
Lexmark x3330 for linux
- Unplug
the printer cable from the computer.
- Unistall the
printer drivers from Device manager and also unistall the all the printer
appications
- restart the
computer
- try to download
drivers from the website
- after installing
drivers and software it will ask you to connect the printer.
- then you can
connect the printer and and try to Print the test page.
Hope this help. Please
Rate My Response! Thanks!
PREM
Printing Problem
Change this **** printer, the color cartriges very expensive and bad recharge. with 3 cartridge cost I have bought a new laser HP
How do i set the time on a lexmark x464
Usually you need to access the embedded web server on the printer by typing the IP address of the printer into your web browser address bar. This will open a window that will have all the settings available.
