20 Most Recent
Lexmark E342n Laser Printer Questions & Answers
LEXMARK E342N
can u explain mean clearly....... restart the machine and then try it........
I need ip
Do you mean to establish a network/internet connection?You can do so through mobile data internet,wifi,through landline or conact an ISP and get modem connection.For eg:you can contact an ISP and request for an internet connection..you will be given access after certain procedures...Once you get connected to the internet you can visit
Ip-details.com to get your network IP
200paper jam remove cartridge
Here is what probably is your problem.... The input sensor number 1 is bad.... It's the sensor directly under the toner and photo conductor.... replace this sensor.
31 Missing or Defective Cart.
Please verify the firmware code on your printer. If its lower than the code below and the printer can go into a ready state after POR, I would suggest you contact Lexmark Technical Support and update the firmware of your printer.Base Code br.h.p204Engine code br.mp.e202 Hope this helps.
