20 Most Recent Lexmark P450 InkJet Photo Printer Questions & Answers
0answers
0answers
Cd stuck in printer
You have a CD stuck in your printer? I won't inquire as to why there is a CD stuck in your printer because it is irrelevant.
Where in the printer is your CD stuck?
8/20/2011 5:18:19 PM • Lexmark P450... • Answered on Aug 20, 2011
Will not recognize jpegs on
Try to insert a different know working cd to determine it's not a disc problem. Try to unplug and re-plug the printer into the power source to reset it.
7/2/2011 9:06:43 PM • Lexmark P450... • Answered on Jul 02, 2011
2answers
Error code 1203
it is catridge error kindly replace the catridges.
11/24/2009 2:41:01 PM • Lexmark P450... • Answered on Nov 24, 2009
Cartridge Error
you can contact Lexmark tech support direct, 1-800-539-6275
International Headquarters and
United States Headquarters
Lexmark International, Inc.
740 New Circle Road NW
Lexington, KY 40550
For Lexmark technical support call:
(800) 539-6275 Monday - Friday 9am - 9pm
Saturday Noon - 6pm
9/12/2009 1:53:19 PM • Lexmark P450... • Answered on Sep 12, 2009
P450
Your cartridge did not fit the requirements of your printer.
6/6/2009 6:32:07 AM • Lexmark P450... • Answered on Jun 06, 2009
Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
1/1/2008 8:44:39 AM • Lexmark P450... • Answered on Jan 01, 2008
Good afternoon. My Lexmark 792 printer shows error 956.02 at startup when adjusting colors, how can I solve it?
The 956.02 error on your Lexmark 792 printer indicates a system board issue. Troubleshoot it step by step: Power off the printer: Turn off the printer and allow it to remain powered off for 10 to 20 seconds before turning it back on. Check the code level: You can identify the current code level using either of the following methods: Method 1: Print the Menu Settings Page: Touch the Menu button on the printer's operator panel. Select Reports. Choose Menu Settings Page to print the page. Look for the code level under Device Information. Method 2: Use the Printer's Embedded Web Server (EWS): Open a web browser (such as Internet Explorer) and enter the printer's IP address. Click on Reports and then select Device Information. Download and install the latest firmware: If your printer's code level matches any of the following: For C792: LHS1.HC.P129 or LHS1.HC.P130 For X792: LHS1.MR.P131, LHS1.MR.P135, or LHS1.MR.P135a For X925: LHS1.HK.P136a Proceed to download and install the latest firmware. If your printer's code level matches any of the following: For C792: LHS1.HC.P131 or later For X792: LHS1.MR.P135b or later For X925: LHS1.HK.P136b or later Contact Lexmark Technical Support for service. Update the firmware: Download the latest firmware from the Lexmark Support website. Save the file and extract it to the same directory. Use the appropriate Authorization Keycode: For Lexmark C792: c792 For Lexmark X792: x792 For Lexmark X925: x925 Update the firmware using one of the following methods: Embedded Web Server (EWS): Open a browser, enter the printer's IP address, and select Settings > Update Firmware. USB utility: Follow the detailed steps for updating via USB flash utility. USB thumb drive: Refer to the steps for updating using a USB thumb or flash drive. FTP: Follow the steps for updating via FTP. If you need further assistance, please contact Lexmark Technical Support. When calling, have your machine/model type and serial number (SN) ready. 956.01 system board error ' Lexmark C792 Error Codes > Lexmark > X792dtse > Code 956.02 (printcopy.info)
4/18/2024 4:49:05 AM • Lexmark Office... • Answered on Apr 18, 2024
What can replace the ibm lexmark wheelwriter 1000
If you're looking for a replacement for the IBM Lexmark Wheelwriter 1000, you might consider a typewriter like the Brother M-1000, the Olivetti Studio 45, or the Smith Corona SR8000. These typewriters have similar features and capabilities to the Lexmark 1000, and they're often considered to be good alternatives.
11/20/2023 6:00:27 PM • Lexmark Office... • Answered on Nov 20, 2023
My computer guy just installed Lexus Mint on my computer and downloaded the proper driver for Pantum 7100 series printer
How do you 'install' Lexus Mint green on your computer? https://www.google.com/search?q=Lexus+Mint
Driver
PANTUM https://global.pantum.com > support > download > dri... Home Service&Support Driver/File Download Driver ... printer. Product Series. Product Name. You may need. Pantum P2500 Windows Driver. Version: V2.6.30.
PANTUM M7100DW Printer Driver Download
trikprinter.com https://www.trikprinter.com > PANTUM Apr 8, 2017 - Install Driver For Printer. Install Print Driver For Windows : Download the file. select the location of the file that is already stored. Double ...
Drivers for printers Pantum M6700 / M6800 / M7100 / ...
DriverFresh.com https://driverfresh.com > DF.com > Printers and MFPs Drivers for printers Pantum M6700 / M6800 / M7100 / M7200-series for Windows 11 - XP (32/64-bit), Mac OS X 12 - 10.5, Linux Ubuntu 20.04 - 12.04 in English.
how do I publish a printer [duplicate]
Ask Ubuntu https://askubuntu.com > questions > how-do-i-publish-... Jan 5, 2013 ยท 1 answer Open the dash and type Printers, then click on the "Printers" icon. That will open up a window that will probably have a list of printers. What is CUPS server and how to share a printer ... 3 answers Oct 28, 2011 HPLIP or CUPS cannot Find Network Printers? 5 answers Jan 25, 2013 More results from askubuntu.com
Deploying Printers to Domain Users and Computers with ...
Windows OS Hub https://woshub.com > Group Policies Nov 8, 2022 - You can publish your shared printers in Active Directory. To do this, enable the List in the Directory option in the printer settings on the ...
Use Group Policy settings to control printers
Microsoft Learn https://learn.microsoft.com > ... > Windows Server Feb 23, 2023 - Describes the policies specific to managing printers and how to enable or disable printer management by using the Local Group Policy Editor. ..
8/13/2023 11:58:46 PM • Lexmark Office... • Answered on Aug 13, 2023
Need drivers for Lexmark 4431
  1. Visit the Lexmark Support Website: Go to the official Lexmark website (www.lexmark.com) and navigate to the "Support" or "Downloads" section.
  2. Enter Printer Model: In the search or product support area, type "Lexmark 4431" or the full printer model number (e.g., "Lexmark 4431-001") and hit Enter or click the search button.
8/6/2023 7:03:20 AM • Lexmark Office... • Answered on Aug 06, 2023
Lexmark P450 InkJet Photo Printer Logo
Popular Tags
16 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lexmark Office Equipment & Supplies
Most Popular Question
ink cartridges needed p450
  • Office Equipment & Supplies
