20 Most Recent
Linksys WRT54GX4 WIRELESS 802.11G BROADBAND ROUTER WITH SRX400 (WRT54G4) Questions & Answers
The internet connection is fine (DSL AT&T).
1. You may have a an IP address conflict.
2. check the device connected to the router
all computer need to be connected at the same time.
3. Bring all the computers up one at a time and this should resolve the address conflict.
I need to get into my router network setting so I
Reset the router to factory defaults by holding the reset key for 15 seconds with power on. Then you'll be able to use the default IP address and password as described previously. Also, the wireless will default to no encryption, so you're all set.
Type 192.168.1.1 into your browser (into the address bar). That is it's default IP. You should be able to change the settings there.
Wrt54gx4 was working and now cannot get a
A simple solution is to plug your modem in to the lan port of your router. A complex solution is to change your lan ip address different then the modem ip address. For example my lan ip for my modm is 192.168,1,1 and my router is 192.168.9.1.
Hi there
Contact the Linksys customer care and ask for a power adapter. Don't tell them that you have lost the adapter. Just let them know that the adapter no longer works. Now here's the catch. You must first call up the technical support; prove to them that the adapter is bad; and obtain a case id. Once you are done, follow the following link and choose the third option - "Ship only RMA request"
https://linksysrma.moduslink.com/Consumer/pag/Homepage.aspx?country=US
Note: The mentioned link will only work for customer in US.
regards
Sandeep
Linksys WRT54GX4 loses internet connection
Not a problem, you have to consider maybe other devices and or networks competing/interferring with your network. If you know how to enter the Linksys router menu I would 1. change the frequency the router operates on 2. change the channel the router will use 3. change the default password to something else besides the default.
All of the settings for your router out of the box are at default, wonder how many other people are running the same thing in your neighborhood? I always change from the default, you may also be receiving interference from devices using the same freq/channel as your router. Changing these will eliminate those possibilities.
Don't forget to encrypt your network, that is most important.
Unsecured network
open 192.168.1.1 in your browser.It will ask for username and password.Leave the username as blank and in password type admin.You will get the linksys pages.Now click on wireless on the black bar at the top.Click on wireless security just under wireless in the blue bar.Select security mode as WEP.In key 1 type any 10 digit no. which will be your security key.Scroll down and click seave settings.now your network is secured.
WRT54GX4 Wireless Router Setup Problems
Hi Randy
Reset the router
Use regular way to configure the Router.
In computer side
Go to Start>Connect To>Show all connections
a new window (Network Connections) will open,
Right click on the "Wireless Network Connection"
Click on "View Available Wireless Networks" You will see "linksys" with the highest signal level. Connect it
after connection go to web browser; type 192.168.1.1 and hit enter. It will take you to Linksys setup page which is integrated in the router. after that you can do any settings you want.
Please post here if you need further assistance
Good Luck
Problem with a linksys ethernet cable router
The router may need to be reconfigure since you lost the internet connection , If you still have the setup CD you can just run it again or better call Linksys Tech support so they can walk you through with the process the number is 800-3267114 you can call them any time of the day..
Hope that helps.......
How Do I Make the Linksys WRT160n Wireless-N Only
Sit at your computer and open up IE browser. After this has opened up, go up to the url bar and erase anything there and when this is blank, type in
http://192.168.1.1
then hit the enter key. The router should now pop up a login menu close to the middle of your monitor. The default password for Linksys routers is ADMIN leave the user name blank and just enter the password ADMIN
This then will open up the routers main menus and at the top of the tabs look for the tab named "wireless" click on this tab and look this menu over and you should find the box to check or uncheck to accomplish what you want done. Good luck. By the way, while your in the routers menu "Change the Default Password" to something that you have to write down! leaving the password set the the factory default is a huge mistake. Like leaving all your windows and doors open going on a long vacation! Got it?
Dennis
Linksys WRT300N router flashing all lights
On the back of the router you will see what looks like a pin hole, turn the router on and use a paperclip to push into the hole(it's a reset button) and keep it pushed in till the router cycles off then on again, it resets the router to default. Hope this helps.
How do I find network key for wrt120n router
Every router I have ever seen allows you to reset the configuration to factory default - but not allow you to retrieve a forgotten password and maintain your settings at the same time. This is often referred to a "factory" or "hard" reset.
When you initiate a factory / hard reset, typically by pressing & holding a button on the router - or behind an opening in the router case - all the changes you've made to it will be returned to the factory default. Wifi becomes "open" with no password (on most devices), the login username / password also go back to default settings (common ones are: admin / admin, admin / password, <blank> / admin, <blank / password, etc.). Consult your router's set up guide or online documentation to learn what the factory / hard reset procedure and the default settings.
Once you gain access to the setup pages of the router, configure it as best as you can remember, and lock it down with good security settings. At minimum - this should include changing the router's username / password, the WiFi's SSID and do not broadcast it, add WPA or WPA2 encryption and secure it with a security or network key (use a mix of numbers, letters, symbols etc.).
I suggest recording all these settings on paper and then tape it to the bottom of the router. There it will remain out of sight - but ready when you need it.
Lost cd for wrt120n
http://downloads.linksys.com/downloads/setupwizard/WRT120N_CD_1.0.01_Windows.zip
