20 Most Recent
Linksys computers10: EtherFast Cable / DSL Router (MC60050) Questions & Answers
Ethernet cable 'splitter': Works on AT@T 'light'
Splitters that work on telephone modems are not designed to work on cable modems. If you are trying to allow more than one computer to access the Internet, you need a broadband router.
You can find them on eBay and at stores for under $30. The primary difference between them is the number of "ports". A port is simply a place to plug in your PC. The more ports, the more PCs you can plug in.
Here's how you set a router up.
1. Plug a short Ethernet cable into the Ethernet "out" port on your cable modem.
2. Plug the other end into the "Uplink" or "WAN" port (will be labeled one or the other.
3. Plug an Ethernet cable into the LAN card on your PC and the other end into one of the open Ethernet ports on the router.
4. Reboot each PC.
You should be good to go!
5/1/2010 8:59:42 PM •
Linksys...
Answered
on May 01, 2010
COMPUTER ROUTERS
Hi there, most routers do have a cd with them but this is nothing more than a manual most of the time. If you just set up your router as the instructions tell you and link it to your pc/laptop using the lan/ethernet cable, then the easiest way to set it up is to open internet explorer which will no doubt say page cannot be displayed...just ignore that. Now in the address bar at the top just type the access address for your router... this will be in your manual and will look something like 192.168.1.1 or 192.168.1.0 you can even try one of the codes i just gave you. Anyway after that you will have a box or page appear requesting a user-name and password. the user-name should be - admin & the password maybe the same or the password could be - password. anyway if all that worked you should be on the router setup page where you can run the setup wizard or just enter your internet provider details eg. user-name and password given when you signed up for broadband. hope all this helps... Tony A
12/13/2008 2:47:44 PM •
Linksys...
Answered
on Dec 13, 2008
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM •
Linksys...
Answered
on Jan 28, 2022
How to Fix Linksys Router Error 2118?
This seems to be a symptom of a configuration error, which can be fixed by resetting the router to factory default. Do this by finding the (often partially hidden) reset button on the device, and pressing and holding down the button, with the power on, till lights start flashing on the router. Let go of the button and allow the router to reset (can take a minute or two). You will now have reset the router to factory default. To connect to your ISP, you'll need to enter your account details (and any other specific information) provided to you by your ISP. You will also have to set a name and password for the wifi section of your router (if it has wifi) if you don't want it to be freely accessible by everyone within wifi range.
7/29/2021 11:33:41 AM •
Linksys...
Answered
on Jul 29, 2021
Why is my Linksys WRT54G wireless-g router not being recognized anymore?
just fixed one yesterday.
the power pack was no good.AC wall wart,
power green LED blinked endless. and the white logo, LED is dead..
a new pack fixed it.
also the wrong pack used, ! do not mix them up. oops.
first year 54G, v1 uses 5vdc pack.
at v2, and up all want to 12vdc pack,
bottom sticker on above failed was v6.
you said recognized, does that mean the 4 rear Ethernet wired jacks are dead, or just wifi dead.?
first the ethernet ports must work, or wifi is doomed.
2/18/2020 11:46:05 AM •
Linksys...
Answered
on Feb 18, 2020
How to fix Linksys router error 321 ?
Good day,
This might be of help .
Steps To Fix Linksys Router Error 321:-
Step1:- Check the Firewall Settings
To check the Firewall Settings is the first priority for the users. Then check the firewall settings of the computer/ Laptop, will be helpful to find the problem. If there is any firewall installed on the computer, so the users need to turn it OFF.During the process, the users ensure that the Local Area Connection on the computer is not disabled. The Local Area Connection should not have any static IP address assigned. If there is any then the users need to immediately set the IP address to automatic.
Method2:- Run the Installation CD Again:-
The users require trying to run the CD again and ensure when the CD runs, it will ask to connect the computer and the modem to the router with the cable. So the users will need to notice, that there all the lights lit up on the router. If it's not, then users will need to setup their router without the CD.
The users can get the instruction to setup router manually in the method 3.
Step3:- Try to Setup Router Without Installation CD
Setup Linksys Router without Installation CD is another best option for users in order to completely avoid the in order to fix Linksys Router Error 321.
Follow the below-given instruction to Setup Linksys Router without Installation CD:
First of all, connect the main computer to the Ethernet port on the router.
Then the users need to connect the modem to the Internet port on the router.
Now it's time to verify the status of the light that is blinking properly.
Next, users need to open the setup page of the Linksys Router and then change the Internet connection settings manually.
In the setup page of the Linksys Router, the users can change the settings of the router as per their needs.
Then the default IP address of many Linksys router is 192.168.1.1. And the default username and password would be an "admin".
Wait for a few minutes, when the main computer is able to access the Internet, so users need to create a wireless network for their wireless computers/devices.
or you can call them @ Toll Free 1-800-204-6959 that is Lynksys support.
2/3/2020 1:14:25 PM •
Linksys...
Answered
on Feb 03, 2020
How to Set Up Linksys WRT54G Wireless G Router
The vent actuators are bad. there should be two. one on each side. they are small toy like motors that open and close the vents from within to allow the hot air to blow by closing the vents to the a/c unit.
11/21/2019 5:05:43 AM •
Linksys...
Answered
on Nov 21, 2019
