20 Most Recent Maytag MER5870 Electric Kitchen Range Questions & Answers
My large burner does not heat up fully...the
The problem with that is going to either be the outer ring of the burner burnt out OR the control sitch for that burner. THier is no fuse for the burners, the switch for that dual burner is part number 74003122,the part the dual burner is 12002144
it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
8/15/2011 4:38:55 AM • Maytag MER5870... • Answered on Aug 15, 2011
0answers
Model 5770ACW 19401490Z. An
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
10/4/2010 6:27:36 PM • Maytag MER5870... • Answered on Oct 04, 2010
F3 f1
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
10/1/2010 4:39:24 AM • Maytag MER5870... • Answered on Oct 01, 2010
Oven will not heat up completely
Hi!
Try the following---
1.) When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
2.) When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Thanks
Rylee
5/16/2009 12:25:02 AM • Maytag MER5870... • Answered on May 16, 2009
2answers
Hello ppeaches,
Are you sure that the oven isn't heating up more than 100 degrees or are you basing the problem on the ovens readback of 100 degrees? If it truly isn't heating more than 100 degrees then anything inside there should be hot but not so hot as that it can't be touched. Have you tried to cook anything in there? My intent to assist in diagnosing the problem is to determine if it is a control based or read back based issue? Try cooking something that requires at least a 350 degree temp and get back to me on what happens... We;ll get you running after that,,,,,
11/17/2008 12:06:16 AM • Maytag MER5870... • Answered on Nov 17, 2008
Fault code f1 came on during a cleaning -
On maytag f1 means there is a problem in the control (erc) and will need to be replaced.
12/26/2007 3:19:17 AM • Maytag MER5870... • Answered on Dec 26, 2007
Stove ignitor does not light burner. How to fix ?
This may sound silly and I know your stove is gas, but is your stove plugged into a power outlet on the wall? Some older stoves had the igniters powered from a wall socket so had to be 'plugged in' and others are powered by replaceable batteries, (AA's or AAA's), with the pack being mounted low down on the front, near one of the front feet. If it is a battery type try changing the battery for a new one. Sometimes the fix is that easy.
10/7/2023 4:48:47 PM • Maytag Kitchen... • Answered on Oct 07, 2023
My maytag gemini oven keypad (numbers only) stopped working.
If the keypad on your Maytag Gemini oven (numbers only) has stopped working, there are a few troubleshooting steps you can try:
  1. Power cycle the oven: Turn off the oven by unplugging it from the power source or by switching off the circuit breaker. Leave it powered off for a few minutes, and then plug it back in or switch the circuit breaker back on. This can sometimes reset the keypad and resolve temporary issues.
  2. Check for physical damage: Inspect the keypad for any physical damage, such as cracks or signs of wear. If you notice any damage, it may be causing the keypad malfunction. In such cases, the keypad might need to be replaced.
  3. Clean the keypad: Over time, dirt, grease, or food particles can accumulate on the keypad, which can interfere with its functioning. Use a soft, damp cloth to gently clean the keypad. Avoid using harsh chemicals or excessive moisture that could damage the keypad.
  4. Test the oven's other functions: Check if other functions of the oven are working properly, such as the temperature controls and other buttons. If only the numeric keypad is affected, it could indicate a specific issue with that part of the keypad or the underlying circuitry.
  5. Contact Maytag customer support: If the above steps do not resolve the issue, it is advisable to contact Maytag customer support or schedule a service appointment with a qualified technician. They will be able to provide further guidance and assistance in diagnosing and fixing the problem.
6/28/2023 5:00:31 AM • Maytag Kitchen... • Answered on Jun 28, 2023
I changed my Maytag over to lp and the oven and broiler don't get propane to it it glows but no flam what's wrong
If you've converted your Maytag oven to LP (propane) and you're experiencing issues with the oven and broiler not receiving propane and not producing a flame, there could be a few possible causes:
  1. Gas supply: Ensure that the propane supply to the oven is turned on and the gas valve is fully open. Check that the propane tank is properly connected and that there is sufficient propane in the tank. If the tank is low or empty, it may need to be refilled.
  2. Incorrect conversion: Double-check that the conversion from natural gas to LP was done correctly. Verify that the conversion orifices have been installed in the correct locations and that the air adjustment shutters or plates have been adjusted according to the manufacturer's instructions. Improper conversion can result in inadequate gas flow and a lack of flame.
  3. Clogged orifices: It's possible that the orifices, which control the flow of gas, have become clogged with debris or residue during the conversion process. Clean the orifices using a small brush or a compressed air canister specifically designed for cleaning gas orifices.
  4. Gas pressure: LP gas operates at a higher pressure than natural gas. Ensure that the pressure regulator on the oven has been adjusted or replaced to accommodate LP gas. If the regulator is not properly set for LP gas, it may not deliver the correct pressure for proper combustion.
  5. Faulty ignition system: If the oven and broiler are glowing but not producing a flame, there may be an issue with the ignition system. Check the igniter for any signs of damage or wear. A faulty igniter may not generate enough heat to ignite the propane. Consider replacing the igniter if necessary.
If you've checked these potential issues and the problem persists, it may be best to contact a qualified appliance technician or the manufacturer's customer support for further assistance. They can provide specific troubleshooting steps or arrange for a service visit to diagnose and resolve the issue with your Maytag oven.
6/18/2023 7:38:29 AM • Maytag Kitchen... • Answered on Jun 18, 2023
Is it normal for the air fryer fan in my Maytag stove to keep turning on and off every few seconds?
Question edited for clarity (typos, fun to fan, of to off). Maytag doesn't mention, but BestBuy says it is normal.
Using the Air Fry Feature
Maytag https://producthelp.maytag.com > Product_Info > Usin... Jun 29, 2022 - Using the Air Fry Feature on Maytag Range or Oven Convection fans will circulate hot air very quickly around the surface of the food, which ...
Just used my Whirlpool convection oven air fryer - Q&A
Best Buy https://www.bestbuy.com > site > questions > question Dec 6, 2021 - Hello, this is a normal operation for the fan to turn on and off to help with air circulation. We hope this helps. ... Sorry, there was a problem.
3/29/2023 3:05:49 PM • Maytag Kitchen... • Answered on Mar 29, 2023
2answers
Maytag Gemini, double oven electric. Replaced bottom element, replaced thermal sensor and tested power. It still won't heat up. WHY?
There are several potential reasons why your Maytag Gemini double oven electric range is still not heating up after replacing the bottom element and thermal sensor and testing the power. Some possibilities include:
  1. The wiring or control board may be faulty and preventing the oven from heating up.
  2. The upper heating element or broil element may also be faulty and need to be replaced.
  3. The oven may not be calibrated properly, which could cause it to not heat up correctly.
  4. There may be a problem with the oven's door latch or switch, which could prevent it from heating up.
2/14/2023 5:03:34 AM • Maytag Kitchen... • Answered on Feb 14, 2023
Maytag precision touch control 800 electric slide-in smoothtop: the Inner element of triple burner stopped working. How to fix it?
The first step to fixing the inner element of a Maytag Precision Touch Control 800 Electric Slide-In Smoothtop is to check the power supply for the range. Make sure all connections are secure and that the outlet is working properly. If the power supply is fine, then you may need to replace the inner element on your range. It would be advisable to consult the manual
1/30/2023 5:34:28 PM • Maytag Kitchen... • Answered on Jan 30, 2023
Maytag MER5870 Electric Kitchen Range Logo
24 questions posted
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Kitchen Ranges
Most Popular Question
model 5770acw 19401490z
  • Kitchen Ranges
