20 Most Recent Linksys Wireless-G WRT54GX Router (WRT54GX2) Questions & Answers
0answers
Trying to connect a Sony Bravia TV
not sure if this link will help you but have a look.. Trying to connect Sony Bravia TV KDL 32EX40B using the Sony Wireless...
10/25/2017 3:36:11 PM • Linksys... • Answered on Oct 25, 2017
Wrt54gx2 won't stay powered up
Has the AC jack been damaged in the Linksys, due to pulling of the cord? Try wiggling the plug at the rear of the linksys to verify the connection. Check, reseat ALL cables. If it's connected to the ISP modem, can you use a Ethernet cable on the Linksys to the computer to verify signal? It may be bad, hard to say for sure.
2/14/2013 1:57:25 PM • Linksys... • Answered on Feb 14, 2013
Why i cant reset my
Hi trenzfall89,
I see that you are resetting your Linksys Wireless Router.
You mentioned you pressed it but it will not reset, if that is a brand new Router, then most probably the plastic covering the reset button is still ther you should press it to go in the Router and get to the Reset Button, the pin that you are using should go in the Router at least to determine that the reset button is really getting pressed on the Router.
Hold it down 15 seconds will be fine also make sure that by doing the resetting the router should as well be turned or Powered ON and not powered OFF to make the reset feature to happen or work on the Router...
If still the Router will not reset then this is probably that the router is not anymore functional nor responding properly anymore, you may need to just get a new router in this case.
I hope this help.
Have a nice day,
mvincentc
6/10/2011 4:00:11 AM • Linksys... • Answered on Jun 10, 2011
My nat type on my
Well this becuse of NAT on the router
you can solve the problem by putting your PS3's IP address on DMZ in the router
access your router page (type 192.168.1.1 in the address bar of internet explorer)
username would be admin and password would also be admin
go to the DMZ and enter the IP address of the PS3 there after enabling it....restart your PS3....bingo your problem solved
Note:- you can check your PS3 IP address in the network settings and connections option on PS3
Hope it helps
Thanks
1/16/2011 5:24:15 PM • Linksys... • Answered on Jan 16, 2011
2answers
I hooked up a new computer to my wireless and it
Your wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
10/6/2010 12:41:41 AM • Linksys... • Answered on Oct 06, 2010
Cannot connect to router
press the reset button on the router for 30 seconds. Then unlpug the power to the router . wait for 10 seconds, plug in the power to the router.
check the IP address on the computer. try to ping the router number. if you get the replies then you will be able to open the router set up page.
Click Here for more information about the router set up
1/14/2010 6:10:02 AM • Linksys... • Answered on Jan 14, 2010
Wep key problems
Plug a computer directly into the router (with an ethernet cable). Then in your browser, go to 192.168.1.1 or 192.168.0.1. You should be able to log into the router from there and adjust the wireless settings.
Hopefully you know the router password...Otherwise you will have to reset the router, in which case, there is usually a small recessed button somewhere on it, that you can hold down for 30sec to reset the router settings to factory defaults.
12/22/2009 8:07:48 PM • Linksys... • Answered on Dec 22, 2009
Unable to set password for router & need tp find assigned WPA code or get a new one
Hi Clawrence,
the WPA key can be found when you log-in to the router's GUI, you may refer to the link below for more information on where to get it.
http://voodoomox.blogspot.com/2008/07/setting-up-your-linksys-router-to-have.html
OR
if you have access to the router please try this: Go to Wireless Tab > Wireless Security (sub tab) and you should be able to see your WPA or WEP key.
should you have other questions, please do not hesitate to let us know.
regards
voodoo
4/20/2009 3:09:11 AM • Linksys... • Answered on Apr 20, 2009
2answers
Linksys WRT54GX2 constantly disconnects
I just upgraded from firmware version 1.01.14 to 1.01.22 and I have the same problem, the router just keeps resetting itself. I think the solution is to go back to the old firmware, but I haven't been able to find a copy yet, Once I find firmware version 1.01.14 for the WRT54GX2 router. I will let you know if this is the solution... :)
WRT54GX2
3/9/2009 8:08:07 PM • Linksys... • Answered on Mar 09, 2009
Wireless Networking With a Linksys Wireless-G WRT54GX Router?
k2rt9ceswg,
You seem rather savvy so I won't bore you with frivolous explanation. Essentially ISPs detect the MAC address of whatever device is plugged into their network. In the case of your laptop connected wired to your modem, the MAC address of your wired adapter is what is tied to your ISP account. When you plugged in a router, the MAC address of that router was different than your laptop's wired network adapter and your ISP said "nope, not letting that connect". This is something most ISPs are doing now-a-days.
You can get around this by following these steps:
  1. Plug your PC back into the modem wired
  2. Ensure you have internet connection again
  3. Go to Start -> run and type "cmd" without quotes
  4. Type "ipconfig /release" without the quotes (there is a space in there that needs to be in there)
  5. Disconnect your PC from the modem and plug the router into it
  6. Plug another LAN cable into the router and your laptop
  7. In the same command prompt, type "ipconfig /renew"
If the computer pulls an IP address for the wired ethernet, you should be all set to disconnect the cable from the router and PC and try to connect to it wireless. If it doesn't pull an IP address, you'll need to contact your ISP and inform them that you're having trouble getting your new router to work with your existing network.
You might also consider depressing the reset button located on the back of your Linksys router to set the router to its default configuration. This would clear all previous settings if there were any and might clear up any configuration options you had set when previously using this router.
3/4/2009 1:46:26 AM • Linksys... • Answered on Mar 04, 2009
Setting linksys WRT54GX Ver2 with D-Link DSL-2450T ADSL2+router
Your router needs to be configured. Call Linksys Technical Support. If they cannot help you try this http://technicalsupport.blog.friendster.com
2/15/2009 11:38:16 AM • Linksys... • Answered on Feb 15, 2009
What is portforwarding
You need to login to your router and go to firewall or virtual servers.  In there you can setup port forwarding.  The goal is to forward external (internet) traffic to a specific internal machine (your PS3).  You do this on a per TCP/UDP port basis and must specify the appropriate external TCP and/or UDP port and internal TCP and/or UDP port.  Sounds harder than it is.
Or you can setup your PS3 in your router's DMZ (Demiliterized Zone).  This sets up the router to forward ALL internet sourced traffic to a specific machine (your PS3).  This is the easier way to do it so you don't have to worry about specific TCP/UDP port numbers.
1/24/2009 10:26:47 PM • Linksys... • Answered on Jan 24, 2009
My web pages
You may need to adjust some of the wireless settings of the router to speed up the wireless internet connection of your computer , You can do that by accessing the router setup page by typing its IP address on the computer that is working fine with the router and if you're not sure on how to do that I advice you to contact this number for technical help 1-877-787-8749 they are open 24/7.......
10/22/2008 3:42:41 AM • Linksys... • Answered on Oct 22, 2008
2answers
Linskys WRT54GX ver.2 with SRX
better to reset the passphase of your router. You need to get into the admin page of the router's webpage. just follow the 'how tos' in the manual. hope this helps
10/17/2008 4:47:04 AM • Linksys... • Answered on Oct 17, 2008
Password for Router
There should be a reset button on this router you must hold that button in for atleast 30 seconds. This will reset your router, you will then have to reconfigure your router with your modem as all settings will go back to manufactures settings! You will then have to go through the steps that you went through to setup the router for the first time. Drop me a line I will help you through this!
4/12/2008 9:51:08 PM • Linksys... • Answered on Apr 12, 2008
Can't connect or even get past setup.
hmmm...
ok, first question:  Are you running the setup CD while the computer has a physical cable connecting it to the router, or are you trying to do this completely over wireless?'
For most wireless routers, initial setup works best using a physical cable.
also, it's possible that the manual reversed username and password:  try USERNAME Admin, BLANK password.
3/28/2008 7:19:27 PM • Linksys... • Answered on Mar 28, 2008
Slow web page loading
To setup and improve your wireless network’s signal, you can change your Wireless Network Name (SSID) and/or try using a different channel.
Changing your Router’s SSID and Channel
Step 1:
Access the router’s web-based setup page.
Accessing the Router’s Web-Based Setup Page
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP Address ("192.168.1.1" is the default IP of most Links-ys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name space blank, type in your router’s password ("admin" is the default password), then click OK.
Step 2:
When the router’s web-based setup page appears, click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to ‘linksys’ change it to something unique then click Save Settings.
click the Wireless tab and select the Wireless Security tab.
Step 3:
Select WEP under Security Mode.
Step 4:
Select any number on the Default Transmit Key field to determine which key you’ll be using. In this example, we selected number one.
Step 5:
Select 64 bits on WEP Encryption
Step 6:
Type a wireless network password of your choice such as “MySecretKey,” then click Generate.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 10 characters.
Step 7:
The result will be a string of random characters. Copy the resulting string since this will be the key to your wireless network.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
And click save settings..
3/19/2008 5:28:27 PM • Linksys... • Answered on Mar 19, 2008
Unstable PS3 connection
good idea to assign your own ip but no need to use dmz...
do the following:
1. reset your router to factory settings, assign urself an ip address (make sure its out of the scope of the dhcp), no need for dmz
2. enable upnp (thats what ps3 uses)
open these specific ports if u are using firewalls
TCP:
  • 80
  • 443
  • 5223
UDP:
  • 3478
  • 3479
  • 3658 should also be opened for voice chat.
also if u want to make it faster use Port forwarding and then forward the above port to your static ps3 ip address and u will get even lower pings to play games and no lag
cheers
smeags
2/28/2008 6:32:07 AM • Linksys... • Answered on Feb 28, 2008
2answers
Zyxel wireless router(p-660hw-t1)
Change the MTU size to your ISP's default!
2/2/2008 6:38:27 PM • Linksys... • Answered on Feb 02, 2008
Linksys Wireless-G WRT54GX Router (WRT54GX2) Logo
33 questions posted
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Linksys Computers & Internet
Most Popular Question
unable set password router need tp
  • Computers & Internet
