20 Most Recent
Maytag MER5770 Electric Kitchen Range Questions & Answers
How to fix the sensor on my stove?
The sensor is not repairable. You need to check to see if it's bad and replace it if it is or look elsewhere for the problem. Should measure around 1,100 ohms at room temperature
Maytag oven won't heat or self clean
Roger. Thank you for the correct model number ! That helped! Your model has a high limit safety thermostat located either in the back of the range or under the cooktop. The service manual does not specify where, but on previous service calls, we find them usually in the back of the range, behind the metal back panel. This has gone bad. Usually after a self clean. 71001844 THERMOSTAT, HI-LIMIT - $43 and simple to replace.
High Limit Thermostat 71001844
I have a Maytag MER5770AAW replacin element
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Replacing a radiant element on
yea sounds like an issue for sure, nut not with the element but hte switches instead, theres a short in one or the other( most likely the dual switch) i wouls reccomend replacing both the switches, the elemenst should be fine.
