20 Most Recent
Logitech (980366) Wireless Headset Questions & Answers
Logitech a-00006 wireless headphone- volume
You might want to call the Logitech Customer Care, try on another computer, if the problem persist, then you should get a replacement for hardware failure. This is covered by warranty terms.
Thanks and have a nice day
J -
8/2/2010 1:19:21 PM •
Logitech...
Answered
on Aug 02, 2010
Battery Replacement
well I know you can buy the battery in them from a third party but Not to sure if its really worth it. I do know there is and issue with these if they sit around for a while and not used it seems like the battery dies even more and then you can not charge it. If you come across not being able to charge it, what I did was take it apart and apply a 1.5 or a AA battery battery to the leads. You will need a multimeter to determine which is negative and positive but what I did was tape some 22 guage wire to the negative and positive ends of a AA battery and apply the positive of the AA to the positive of the battery in the treo and negative to negative. You only need to hold it there for 3-5 secs and then you should be able to charge it.
8/22/2009 8:16:14 AM •
Logitech...
Answered
on Aug 22, 2009
I have just bought
Start on the Mac side by checking your sound input preferences. Do this by selecting under the apple pull down menu: System Preferences. Then get to the screen where you see all preferences icon's shown and select Sound. Once in the Sound preferences, select Input. Where is says "Select a device for sound input:" It is probably set to USB audio device since that worked for you. Look for Bluetooth Audio Device or similar name for your headset and select it. Speak into the h760 and adjust the input volume, you should see the input level go up when you speak. If not, your H760 bluetooth device is not properly paired. If your device does not show up, back up to the System Preferences page and select Bluetooth and follow instructions there. If that all is working but does not work in Parallels, inspect Parallels for Sound Input options and try to find your bluetooth device. Also check Windows sound input control panel to see that bluetooth is selected.
Hope this helps.
