20 Most Recent Maytag MGR5870 Gas Kitchen Range Questions & Answers
My oven door will not shut, i have a code of F9
it MAY be your oven door lock is jammed..
I found this information for you:
  • Wait at least one hour after the oven has completed a self clean cycle to attempt to open the oven door, as the oven remains locked until the interior temperature has cooled sufficiently.
  • 2
    Press "Cancel" and wait a few minutes if the oven is cool and wait until at least one hour has elapsed since the completion of a self-clean cycle.
  • 3
    Open the oven door and check the door lock switch. Move the switch back and forth with your fingers to return the switch to the original position. Check for dirt or debris that may be causing the switch to stick or lock and clean as necessary.
  • 4
    Contact an authorized service technician if the problem is not resolved, as the door switch may need to be replaced.
  • Perhaps you can get some advice from Maytag
    Call the dealer from whom your appliance was purchased or call Maytag Appliances Sales Company, Maytag Customer Assistance at 1-800-688-9900
    9/13/2011 12:13:56 AM • Maytag MGR5870... • Answered on Sep 13, 2011
    Tried to clean oven (self
    How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to
    2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for the F1 and listen for the beep.
    7. If you get the F1 and beep, replace the ERC.
    8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
    10/25/2010 3:56:43 AM • Maytag MGR5870... • Answered on Oct 25, 2010
    L.E.D is flashing F9
    H check your door latch cannection
    2/8/2010 6:28:36 PM • Maytag MGR5870... • Answered on Feb 08, 2010
    I have two things I have been disappointed with my
    The problem with the oven sounds like one of the common ones. I have seen this a lot lately. It is caused be the oven thermostat being out of calibration. When you are cooking something at 350 degrees, try setting the thermostat at 310 degrees (make sure to preheat although I'm sure you are) If this does not fix the problem, it will at least help it. If you unit is still under warranty, call Maytag for service and they will correct the problem. If they can't repair it, they are real good about exchanging unit with new ones. As far as the burners, this is a problem they are having and it looks like they can't fix it. The burners get so hot that they can't seem to find anything to stay on them that will not burn over time. I hope this helps.
    10/13/2009 5:42:37 PM • Maytag MGR5870... • Answered on Oct 13, 2009
    Maytag oven will not get hot
    the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
    9/29/2009 3:30:02 PM • Maytag MGR5870... • Answered on Sep 29, 2009
    Oven heats very slowly
    If your top burners work ok, regulator should be ok. Majority of times the fail part in the oven is the ignitor...turn oven on and check for a flame after 10 mins. small flame could mean a bad safety valve.
    6/9/2009 12:09:18 AM • Maytag MGR5870... • Answered on Jun 09, 2009
    Error message and alarm
    These are the fault codes for your unit
    Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
    or
    F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
    Hope this helps, Please take the time to give this solution a fix ya rating
    clarkco
    2/27/2009 2:11:57 PM • Maytag MGR5870... • Answered on Feb 27, 2009
    Stove ignitor does not light burner. How to fix ?
    This may sound silly and I know your stove is gas, but is your stove plugged into a power outlet on the wall? Some older stoves had the igniters powered from a wall socket so had to be 'plugged in' and others are powered by replaceable batteries, (AA's or AAA's), with the pack being mounted low down on the front, near one of the front feet. If it is a battery type try changing the battery for a new one. Sometimes the fix is that easy.
    10/7/2023 4:48:47 PM • Maytag Kitchen... • Answered on Oct 07, 2023
    My maytag gemini oven keypad (numbers only) stopped working.
    If the keypad on your Maytag Gemini oven (numbers only) has stopped working, there are a few troubleshooting steps you can try:
    1. Power cycle the oven: Turn off the oven by unplugging it from the power source or by switching off the circuit breaker. Leave it powered off for a few minutes, and then plug it back in or switch the circuit breaker back on. This can sometimes reset the keypad and resolve temporary issues.
    2. Check for physical damage: Inspect the keypad for any physical damage, such as cracks or signs of wear. If you notice any damage, it may be causing the keypad malfunction. In such cases, the keypad might need to be replaced.
    3. Clean the keypad: Over time, dirt, grease, or food particles can accumulate on the keypad, which can interfere with its functioning. Use a soft, damp cloth to gently clean the keypad. Avoid using harsh chemicals or excessive moisture that could damage the keypad.
    4. Test the oven's other functions: Check if other functions of the oven are working properly, such as the temperature controls and other buttons. If only the numeric keypad is affected, it could indicate a specific issue with that part of the keypad or the underlying circuitry.
    5. Contact Maytag customer support: If the above steps do not resolve the issue, it is advisable to contact Maytag customer support or schedule a service appointment with a qualified technician. They will be able to provide further guidance and assistance in diagnosing and fixing the problem.
    6/28/2023 5:00:31 AM • Maytag Kitchen... • Answered on Jun 28, 2023
    I changed my Maytag over to lp and the oven and broiler don't get propane to it it glows but no flam what's wrong
    If you've converted your Maytag oven to LP (propane) and you're experiencing issues with the oven and broiler not receiving propane and not producing a flame, there could be a few possible causes:
    1. Gas supply: Ensure that the propane supply to the oven is turned on and the gas valve is fully open. Check that the propane tank is properly connected and that there is sufficient propane in the tank. If the tank is low or empty, it may need to be refilled.
    2. Incorrect conversion: Double-check that the conversion from natural gas to LP was done correctly. Verify that the conversion orifices have been installed in the correct locations and that the air adjustment shutters or plates have been adjusted according to the manufacturer's instructions. Improper conversion can result in inadequate gas flow and a lack of flame.
    3. Clogged orifices: It's possible that the orifices, which control the flow of gas, have become clogged with debris or residue during the conversion process. Clean the orifices using a small brush or a compressed air canister specifically designed for cleaning gas orifices.
    4. Gas pressure: LP gas operates at a higher pressure than natural gas. Ensure that the pressure regulator on the oven has been adjusted or replaced to accommodate LP gas. If the regulator is not properly set for LP gas, it may not deliver the correct pressure for proper combustion.
    5. Faulty ignition system: If the oven and broiler are glowing but not producing a flame, there may be an issue with the ignition system. Check the igniter for any signs of damage or wear. A faulty igniter may not generate enough heat to ignite the propane. Consider replacing the igniter if necessary.
    If you've checked these potential issues and the problem persists, it may be best to contact a qualified appliance technician or the manufacturer's customer support for further assistance. They can provide specific troubleshooting steps or arrange for a service visit to diagnose and resolve the issue with your Maytag oven.
    6/18/2023 7:38:29 AM • Maytag Kitchen... • Answered on Jun 18, 2023
    Is it normal for the air fryer fan in my Maytag stove to keep turning on and off every few seconds?
    Question edited for clarity (typos, fun to fan, of to off). Maytag doesn't mention, but BestBuy says it is normal.
    Using the Air Fry Feature
    Maytag https://producthelp.maytag.com > Product_Info > Usin... Jun 29, 2022 - Using the Air Fry Feature on Maytag Range or Oven Convection fans will circulate hot air very quickly around the surface of the food, which ...
    Just used my Whirlpool convection oven air fryer - Q&A
    Best Buy https://www.bestbuy.com > site > questions > question Dec 6, 2021 - Hello, this is a normal operation for the fan to turn on and off to help with air circulation. We hope this helps. ... Sorry, there was a problem.
    3/29/2023 3:05:49 PM • Maytag Kitchen... • Answered on Mar 29, 2023
    2answers
    Maytag Gemini, double oven electric. Replaced bottom element, replaced thermal sensor and tested power. It still won't heat up. WHY?
    There are several potential reasons why your Maytag Gemini double oven electric range is still not heating up after replacing the bottom element and thermal sensor and testing the power. Some possibilities include:
    1. The wiring or control board may be faulty and preventing the oven from heating up.
    2. The upper heating element or broil element may also be faulty and need to be replaced.
    3. The oven may not be calibrated properly, which could cause it to not heat up correctly.
    4. There may be a problem with the oven's door latch or switch, which could prevent it from heating up.
    2/14/2023 5:03:34 AM • Maytag Kitchen... • Answered on Feb 14, 2023
    Maytag precision touch control 800 electric slide-in smoothtop: the Inner element of triple burner stopped working. How to fix it?
    The first step to fixing the inner element of a Maytag Precision Touch Control 800 Electric Slide-In Smoothtop is to check the power supply for the range. Make sure all connections are secure and that the outlet is working properly. If the power supply is fine, then you may need to replace the inner element on your range. It would be advisable to consult the manual
    1/30/2023 5:34:28 PM • Maytag Kitchen... • Answered on Jan 30, 2023
    2answers
    I got a Maytag Gemini range and the front left burner smells like it's leaking gas when the knobs are all off
    If you smell gas coming from your Maytag Gemini range, it is important to take immediate action. Gas leaks can be dangerous and can cause fires or explosions. Here are a few steps you should take:
    1. Turn off the gas supply to the range: Locate the gas shut-off valve for the range and turn it to the "off" position. This will stop the flow of gas to the appliance.
    2. Open windows and ventilate the area: Open windows and doors to allow fresh air to circulate. This will help dissipate the gas fumes.
    3. Do not use any electrical switches, appliances, or light fixtures: The sparks from these devices could potentially ignite the gas.
    4. Leave the house: If you suspect a gas leak, it is best to evacuate the house and go to a safe location.
    5. Call for professional help: Contact a gas company or a licensed appliance repair technician to repair the gas leak and check for any other issues with the appliance.
    1/8/2023 3:39:53 PM • Maytag Kitchen... • Answered on Jan 08, 2023
    Seeking salvage 7601P428-60 timer control for Maytag gas range model 6498VVV. Sourcing suggestions?
    It seems that the 7601P428-60 timer control is a discontinued part and may no longer be available from Maytag or other retailers. Your best bet for finding this part would be to check with appliance repair shops in your area, as they may have used or refurbished parts available. You could also try searching online marketplaces such as eBay or Etsy, as well as appliance forums or Facebook groups where people sell or trade appliance parts. Keep in mind that these sources may not always have the part in stock, and it may take some time and effort to find a seller who has the part you need.
    1/6/2023 8:05:56 PM • Maytag Kitchen... • Answered on Jan 06, 2023
    Sab bath error code for my maytag oven MGRH865QDW1
    Hi and welcome to FixYa, I am Kelly.
    Press and hold the clock button for at least 3 seconds to stop the sabbath mode. This should bring it back to normal operation. If not just respond here and I can walk you through the lengthy diagnostic cycle to clear it.
    Thanks for choosing FixYa,
    Kelly
    1/5/2023 10:52:30 AM • Maytag Kitchen... • Answered on Jan 05, 2023
    2answers
    My Maytag MER5755QAS oven won't heat up. My broiler will not work at all. I choose Bake, set to 350 degrees & it reverts back to 100 degrees and just stays there. My range top works perfectly.
    A Maytag oven not heating at all may be due to a blown thermal oven fuse. Your oven's thermal fuse is a protective feature that trips when the oven overheats
    11/20/2022 4:04:47 PM • Maytag Kitchen... • Answered on Nov 20, 2022
    Maytag MGR5870 Gas Kitchen Range Logo
    17 questions posted
    Top Maytag Kitchen Ranges Experts
    vince
    Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
    View Most Popular
    • Maytag Kitchen Ranges
    Most Popular Question
    l e d flashing f9
    • Kitchen Ranges
