20 Most Recent
Logitech (980408) Wireless Headset Questions & Answers
I hear my own voice when I talk on Logitecs H600 wireless headset
IF you are in Windows 7: -
1. Click "Control Panel" > "Sound" > "Recording"
2. Place cursor over "Microphone - Logitech Wireless Headset Default Device".
3. Right Click and select "Properties"
4. Click the "Listen" Tab
5. Uncheck the "Listen to this device"
6. Click "Apply",. and "OK"
That will eliminate you hearing any nose picked up by the microphone. Others will still be able to hear your voice as long as you have the headset as your default microphone.
3/3/2014 10:08:06 PM •
Logitech...
Answered
on Mar 03, 2014
Logitech HS04 V01 connection
Try turning off the headset. Then setting your phone to look for bluetooth device. Touch and hold for ten seconds the larger button on the headset, should flash blue light rapidly. then command phone to find device, (commands differ from one phone to another). When phone "finds" headset blue light should change to intermediate flashing (three flashes every five seconds aprox.)
Hope this helps..
2/2/2009 3:23:42 AM •
Logitech...
Answered
on Feb 02, 2009
How to pair the device
press 10s the "volume up" button
next on your mobile phone "search for a new device"
code is "0000"
press 5s the same button to activate connection when paired
press 3s same button to switch off*
regards
8/30/2008 3:41:17 PM •
Logitech...
Answered
on Aug 30, 2008
Logitech Wireless Headset pairing password
it should be "0000", i have also a logitech wireless (bought in france)
the only "system" button is "volume up"
press 10s to pair
press 5s to activate a bt connection
press 3s to desactivate the headset
12/17/2007 8:37:01 PM •
Logitech...
Answered
on Dec 17, 2007
I have just bought
Start on the Mac side by checking your sound input preferences. Do this by selecting under the apple pull down menu: System Preferences. Then get to the screen where you see all preferences icon's shown and select Sound. Once in the Sound preferences, select Input. Where is says "Select a device for sound input:" It is probably set to USB audio device since that worked for you. Look for Bluetooth Audio Device or similar name for your headset and select it. Speak into the h760 and adjust the input volume, you should see the input level go up when you speak. If not, your H760 bluetooth device is not properly paired. If your device does not show up, back up to the System Preferences page and select Bluetooth and follow instructions there. If that all is working but does not work in Parallels, inspect Parallels for Sound Input options and try to find your bluetooth device. Also check Windows sound input control panel to see that bluetooth is selected.
Hope this helps.
