20 Most Recent
Lucent Merlin Legend MLX-10D Phone Questions & Answers
I have an extension on
There's a website that you will be able to download the user's manual. From the manual you can see as to how you will reset your password on the phone.
Please just
click_here so that you will be able to download it for free.
You may want to
click_here as well, this will be your future reference.
Thanks.
We have a Merlin System, the phones are MLX-10D,
Sounds like one (or more) of your lines are out in your telephone system. Each time you press a 9 for a line the system simulates a dialtone to see what your dialing next so it can check it against the automatic route selection table. After it checks, it pulls a line out of a pool group to complete the call. At this point its grabbing a line that is not working on the system.The best way to figure out which ones arent working is to check the lines on the main console by pressing each line button and seeing if it produces dialtone. More than likely(but not allways) its going to be a line problem from your dialtone provider.
Setting the Time on MLX-10D
This is where the fun is going to begin. An MLX-10D is a phone. The time is in the sysem, a Legend or Magix. The time is set from the system console, usually an MLX-20L phone (bigger lots of buttons).
If you have one of those, it's easy and ehre are the directions:
To change all Merlin Legend / Merlin Magix system
The time and date is a system feature rather than an individual telephone feature.
To change the date in the Legend Magix system, from the System Programming console:
1.-
Press Menu
2.-
Press System Program.
3.-
Press Exit or Start.
4.-
Press System.
5.-
Press Date.
6.-
Enter date in following format: mmddyy (where MM is the month, DD is the day, and YY is the year).
7.-
Press Enter.
8.-
Press Exit or Back.
9.-
Press Home or Exit to exit programming mode.
To change the time in the Legend Magix system, from the System Programming console:
1.-
Press Menu.
2.-
3.-
Press Exit or Start
4.-
Press System.
5.-
Press Time.
6.-
Enter the time in military/24 hour format: HH:MM (where HH is the hour, 01-24, and MM is minutes, 00-60).
7.-
Press Enter.
8.-
Press Exit or Back.
9.-
If you DON'T have a 20L, then you have to use WIN-SPM to change the time from the cabinet or it can be done remotely IIRC.
If none of these work, or it does, please comment back.
Carl
Lucent MLX-20L Extension Edit
http://dstech1.com/changing-the-name-on-an-extension/
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
- Press Menu.
- Press System Program.
- Press Exit or Start.
- Press More or Right Arrow Key.
- Press Labeling.
- Press Directory.
- Press Extension.
- Dial the extension number that you want to administer.
- Press Enter.
- Press Drop.
- Enter the label information for the extension number selected.
- Press Enter.
- Press Exit or Back.
- Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use
the buttons next to the display to specify the letters A through I and
punctuation. Use the line/feature buttons to specify additional alphanumeric
characters for labels. Use the template provided with the System Programming
console to see which line buttons correspond to which alphanumeric characters,
I am trying to change
A password needs to be changed in Merlin Mail, but we can't get the original password to work. How do we change this so someone else can use it?
