20 Most Recent
Maytag MGR5875QD CleanDesign Gas Kitchen Range Questions & Answers
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
I am trying to reinstall
I couldn't figure out the butter knife trick, but I want to thank you for motivating me. Purchasing new hinges worked 2 years ago, but these simply wear away much too quickly (the little depressions that hold the angle wear away). I tried pulling them open with strong string pulled tight using a tourniquet (this worked with one). Then, I wedged a small piece of shingle behind the offensive thing (like a peg in a lobster claw). If I have to do this again I would start with the wedge, you have to make sure to construct it thin enough to follow the hinge into the final socket. Once the hinge was resting properly I was able to pull it out. Be careful here, the hinges are powerful.
Oven sets off co detector
Then the gas is not burning correctly, the problem can be any number of things, but please have it checked right away, CO is a killer, and you just pass out never to wake up, happened to a friend.
Were can i get an
You can download and print the instruction manual in PDF format by clicking this
link.
To download the installation manual, click
here
You can also download the manual from the manufacturer's support website by clicking this link:
http://www.frigidaire.com/manuals
On the page which opens, enter the model number
GLGF377CSB in the search box and click the
Search button.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using
FixYa.
Frigidaire electrolux gallery series
stoveboy,
I know you probably have the problem fixed by now, but I had the same problem with my frigidaire range just the other day. Loud popping sound, range/clock controls do not work. Stovetop still works great.
I took the back off the stove and got to the circuit board. Unplug the connector and the five spade connector wires. Once you do that, remove the 4 screws holding the entire assembly in place. The circuit board(s) are held in the housing with retaining clips on the housing. Use a small screwdriver or similar to pull back on each clip to pry each side of the board out. Once the board(s) are free, look in between the two circuit boards and you will see the problem. The larger, 20 amp relay is the culprit. It blew traces off of both boards making it almost impossible to repair. Without having a schematic to go by, I went ahead and decided to just replace w/ new boards as opposed to trying to solder the traces. I have not checked on prices, but brief web searches didn't return any results. The board part # is SF5301-S7509-N
Maytag Range Control Panel Issue
Well it seems that the control panel of your oven is dead.
1) Touch panel is not repairable and has to be replaced
2) There is suppose to be tech sheet inside the control panel.
Please follow the below link to get the replacement part (control panel) -
http://www.repairclinic.com/Appliance-Parts?s=t-CHE9800BCB-%3d%3dc212
Please Post comments if you need more help or information......
Thanks
Maytag MGR58750DB oven not working properly
hi bberg thats your ignitor.its right at the brink of failing.so because of its weakness it lets some gas in then gives up and then will try again.its located under the oven pan and a failing one will have a soft glow,new one a brite glow.you can buy one one line or at your local appliance store.about 50$.please help me with my rating if i have been helpful.God bless ypur house,tom
Maytag MGR5875QD stove problem
bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Mgr5875qdw
Hello sfgelectric,
Welcome,
You said, your broiler and oven won't work. That you set bake and it beeps and the bake light flashes but oven wont light.
Does the display flash any error codes, or just the bake light?
Fault codes
1. BAKE or LOCK may flash rapidly in the display to alert you if there is an error
or a problem. If BAKE or LOCK appear in the display, press the CANCEL pad.
2.If BAKE or LOCK continue to flash, disconnect power to the appliance.
3.Wait a few minutes, and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized servicer.
4.If the oven is heavily soiled, excessive flareups may result in a fault code during
cleaning. Press the CANCEL pad and allow the oven to cool completely, wipe out
excess soil, then reset
For most concerns, try these first.
Check if oven controls have been properly set.
Check to be sure plug is securely inserted into receptacle.
Check or re-set circuit breaker. Check or replace fuse.
Check power supply
I'll check the repair manual to see what I can find.
Let me know how it goes.
Perhaps this will fix a glitch.
Huuum
Remember to leave a rating.
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Oven does not work
most common cause of gas range, oven not heating is a result of a faulty oven ignitor, you would need to verify power(110volts) to ignitor, located under iven floor attached to the bake burner. simple enough job for the homeowner to replace probalby about 50-75 for part
