20 Most Recent
Mustek DV-3500 DV Digital Camcorder Questions & Answers
Fully delete memory
Get your self a memory card i have a 2 gig card it works great i tried 4 gig dont work
good luck Bill
Cant get any video to
Does
the screen play back the pictures ok but not during record mode? Or is
it off all the time and you used a computer to review the shots that
were taken?
Check the basics listed below:
1. The screen may be switched off. Press the display button on the back while the camera is on.
This toggles the display setting between various settings such as
Off/ On / Info. Keep pressing the button to try the aternate modes, it just goes round and round to 2 -3 different modes.
2. Check that the monitor brightness setting is set to medium at least
in the menu's.
3. If the problem is only affecting recording
then check that
the main record settings are correct for the type of scene you are
taking. For
example don't use Beach, Snow, Candle or manual with a high shutter
speed while taking regular daylight shots with minimal lighting.
4. If the LCD display has a hardware issue you could connect the camera
to a TV using the video output jack and look at it that way. Then
you'll know if the built-in LCD is ok or not.
5. Having a
damaged or stuck video output jack COULD cause this problem also since
that circuitry is designed to automatically shut off the built-in LCD
display when you connect a video cord to it. Note that having a video cable plugged
in to the video output jack would shut off the display also. Such as when you have it connected to a TV.
Keep us updated.
Manuals
Sure thing, it was tough to find but I have it for you, and put it on my personal web server just for you so that you can view it / download it. Please make sure you rate my help 4 thumbs up if you find it helpful! Thanks so much for understanding. Here is the manual:
http://micromatikal.dlinkddns.com:8000/cust/mustek.PDF
User manual
Go to
http://www.mustek.com.tw/Support/FAQ/PDF/CDV/DV2032/dv2032_en.pdf
and download the Manual
Movavi video editor 11
which type of system you use ? if your computer is not equipped with the requirement, this will not work properly,
