20 Most Recent
Maytag MGC5430BDS Gas Cooktop Questions & Answers
How can I clean the black cooktop grids?
put in kitchen sink with hot hot water over night, with dish washing liquid. preferbly when kitchen is not being used. (After dinner time) drain then spray with mr muscle oven cleaner give it about an hour, then scrub the **** out of them with a stainless steel goldilocks. Rinse then soak in hot water again for 20 minutes then drip dry. After use when cooking always clean any mess left behind. Wipe down so it is easier for you to wash when needed.
9/6/2012 3:18:53 AM •
Maytag...
Answered
on Sep 06, 2012
Sparker turned on by itself
The ignitor is likely shorting out. Either the ignitor, or wires to the ignitor or the switch is bad. They should come fix it for free since it is under warranty. Even if a tech from the manufacture has to come out, it is under warranty so it should still be free. Partselect,com has the parts, diagrams, and more for your unit.
10/26/2010 6:46:49 PM •
Maytag...
Answered
on Oct 26, 2010
Parts Replacement
twist the burner to releace them . remove all 4 and the screws around the sides the lift top .. cook tops have to be completly disambled . for service .. mm
7/22/2010 11:40:05 PM •
Maytag...
Answered
on Jul 22, 2010
Missing manual and gas diffuser
May I get the make and model # to help you get the manual.
Also from the gas supply from house to cooktop it should go like this.
gas valve
gas line
regulator
then cooktop
5/31/2010 5:29:43 PM •
Maytag...
Answered
on May 31, 2010
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
