20 Most Recent NEC MT850, MT1050, MT1055, MT1056 Replacement Projector Lamp - MT50LP Projector Lamp Questions & Answers
The status light is on our NEC MT850 and the bulb looks fine. What other problems could it be?
1,Check the fans ,whether each fan is running,when you turn on the projector 2,if the fans run, then ,check the lamp or lamp ballast turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp) means the lamp may be fault,and other parts is working well Have a nice day! We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry Lampdeng Limited
8/25/2016 4:17:59 AM • NEC MT850,... • Answered on Aug 25, 2016
Projector too bright
8/25/2016 4:03:59 AM • NEC MT850,... • Answered on Aug 25, 2016
What does it means of 6 seconds red light interval of my NEC MT1050 projector,and how will I fix it to come back to life?
Holding down the "OFF" key on the remote control for 30 seconds to reset the lamp timer Have a nice day! We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry Lampdeng Limited
8/24/2016 9:19:37 AM • NEC MT850,... • Answered on Aug 24, 2016
I turn my mt850 on & the picture is blue
You most likely have a defective blue LCD panel which is a common problem for a projectors this old.
This is an exspensive repair if parts are still available, probably not worth fixin.
7/8/2014 2:54:28 AM • NEC MT850,... • Answered on Jul 08, 2014
I have an nec mt850, my picture is upside down...how do i fix that?
Unit is probably set for ceiling mount or reverse screen projection. In the options menu there will be settings to alter it back to normal aspect.
5/15/2013 2:50:49 AM • NEC MT850,... • Answered on May 15, 2013
I have a nec 1050.
It sounds like a polariser lens has failed, if so it may be cheaper to purchase a new projector than have it repaired.Hope I was of assistance to you
8/5/2011 12:11:46 PM • NEC MT850,... • Answered on Aug 05, 2011
How do I reset the
On some Projectors that I used to service, Holding the power button whilst plugging into power did a lamp timer reset. ( Of course check the lamp is fully seated and the lamp door is closed
2/24/2011 12:59:42 PM • NEC MT850,... • Answered on Feb 24, 2011
I have a NEC MT850 projector. The problem is when
How old is the lamp?
12/4/2010 12:05:54 AM • NEC MT850,... • Answered on Dec 04, 2010
2answers
Just purchased a new replacement
There is a lens that overlays the CRT or LCD screen right before the lenticular lens. This can grow old and wear thin. As to let too much color through causing this effect.You need to replace the lens.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
8/12/2010 2:07:53 AM • NEC MT850,... • Answered on Aug 12, 2010
Any body can give an idea how can i acquire a nec
Lots of places online that sell your lamp. If you are not picky about getting a new or used lamp, you should try ebay.
7/2/2010 5:22:19 PM • NEC MT850,... • Answered on Jul 02, 2010
2answers
I have a NEC mt1055
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
1/26/2010 12:39:21 PM • NEC MT850,... • Answered on Jan 26, 2010
MT850 has double image or ghost image, how do you
one of the lcd panels or more then just one r bad.
cost of thuse lcd panels r more then what this old projector worth
1/21/2010 5:47:10 PM • NEC MT850,... • Answered on Jan 21, 2010
Red coured picture Nec MT850
I don't think it's globe related, I'd be getting a quote on the electronics.
1/17/2010 11:50:05 AM • NEC MT850,... • Answered on Jan 17, 2010
2answers
My NEC MT850 projects with a pink picture you can
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
1/17/2010 11:49:03 AM • NEC MT850,... • Answered on Jan 17, 2010
MT1055 power light and stand by light come on but thats all
Have you checked for a fusable link? Typicaly high end units and some low end units have a fuse that takes the blow before the system does...Check for a black cap that unscrews from the unit (or any other variaton. Also the fuse could be internal....If this is the case you may have to disassemble the unit and find the fuse located on the main board of the unit. However if the unit is under warranty it is best to send it back to the manufacturer due to the possibility of voiding the units warranty. I hope this helps you out.
10/7/2009 3:26:50 AM • NEC MT850,... • Answered on Oct 07, 2009
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
5/1/2009 5:26:21 PM • NEC MT850,... • Answered on May 01, 2009
3answers
NEC MT850
As there were no indicator lights lit I focused on the AC. The projectors work as they should in another location and as such I am fairly certain the problem is associated with the AC power in the particular room. I haven't isolated the exact condition as yet.
Thanks
3/24/2009 3:14:08 AM • NEC MT850,... • Answered on Mar 24, 2009
27 questions posted
Top NEC Office Equipment & Supplies Experts
Alexander
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Office Equipment & Supplies
Most Popular Question
nec 1050
  • Office Equipment & Supplies
