20 Most Recent
Nokia IP350 (NBB335F000) Firewall Questions & Answers
Bootmgr Problem
hello I see your comment having some issues also with the same type of unit Nokia IP350 but cant logon ... missing original password ... Could you help me to reset password or send me a copy of the manual
Regards
Problem with CLI
It sounds like the DB connector still has a few pinouts set up incorrectly. Nokia has exact specs listed for pinouts on their website. I recommend matching that up perfectly. If that doesn't work then the console port could be bad, but that is rare.
How to Install Nokia MTK USB Serial Port Driver
How To Install Nokia MTK USB Serial Port Driver: Step 1: First Download (WinRAR/ 7-Zip) Software And Install On Your Computer. Step 2: Download Nokia MTK USB Serial Port Driver, Then Right Click And Extract Files On Your Computer. Step 3: Open Nokia MTK USB Serial Port Driver Folder. Step 4: Now Select (Nokia MTK USB Serial Port Driver.exe) And Right Click To Select Run As Administrator. Step 5: And Then Next- Next- Finish. Step 6: Then Restart Your Computer. Step 7: Now Your Nokia MTK USB Serial Port Driver Install Complete.
How can i get my nokia c2-01 from test mode?
To exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
Difference between fipa & fifa in nokia flexi
TNC Male Connector is used in FIFA card.
2> SMB Connector is used in FIEA card.
3> RJ48c Connector is used in FIPA card.
here is two types of Tx card used in Flexi BTS
1.)FIFA
2.)FIPA
pwsb is known as power supply card and it is used for the power distribution to trx cards in case of ultra bts and dtrx cards in case of flexi bts
Charging and opening problem in NOKIA TA-1053?
Lightly insert a toothpick into the charge port and gently scrape back and forth to clean the contacts. If the tip of the toothpick comes out dark colored, repeat the process a few times.
