20 Most Recent Maytag MTF2156GEW Top Freezer Refrigerator Questions & Answers
Freezer and refrigerator too cold
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
12/27/2010 10:09:03 PM • Maytag... • Answered on Dec 27, 2010
Fridge and freezer no longer cools but big black
The compressor can make enough heat if it is locked up to still make that warm...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
9/17/2010 3:12:43 AM • Maytag... • Answered on Sep 17, 2010
Icemaker on our MaytagMTF2156GEW top freezer
Good day,
Yes, the ice maker controls the water valve in the sense it turns the valve on for approx. 7 seconds per cycle.
However, it is not the common method for causing flooding. 99% of the issues are caused by the valve refusing to close properly.
The only way the ice maker could be at fault is if it hung at that precise position and refused to advance to it's normal parked position.
However, there is the 1%.
5/29/2010 5:11:51 PM • Maytag... • Answered on May 29, 2010
Water not dispensing from side by side fridge
check the primary water valve ,does it make a noise when you push the dispenser ?
3/30/2010 3:42:13 AM • Maytag... • Answered on Mar 30, 2010
2answers
Freezer gets cold refrigerator doesn't
check the damper door located between the freezer and refrigerator compartments(this lets in the cold air from the freezer) and make sure it opens and closes with your temp adjustment in the refrigerator compartment,sometimes they ice-up and are frozen in one position then take a hair dryer and defrost the door
3/13/2010 10:29:32 PM • Maytag... • Answered on Mar 13, 2010
The refrigerator no longer cools. The freezer
ok take your shelves off
the center air hum, it will take a lil strength but lift the air channel up thaen pull staright out, is should pop right out and give you access to the fan...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=49270&diagram_id=635220#d635220
makse sure you order the correct part 7
does your fan have a blue and white wire
10/22/2009 11:54:20 AM • Maytag... • Answered on Oct 22, 2009
When ice maker draws water the supply line leaks
more than likely you have a friction leak in the water line the hissing sound is the actual water stream
hitting the wall,
the friction leak is common from the hose jumping when water pressure is first applied
a simple water union can fix this quickly and cheaply
10/3/2009 11:55:11 AM • Maytag... • Answered on Oct 03, 2009
How do you install maytag "mbb1954g" ice maker plastic water line connection to the freezer?
To connect the water supply using a plastic hose kit to the MBB1954G UNIT, you can follow these steps: Turn off the water supply valve under the sink. Remove the old hose from the water supply valve and the back of the refrigerator. Attach the new plastic hose to the water supply valve and the back of the refrigerator. Make sure the hose is not kinked or twisted. Tighten the fittings with an adjustable wrench. Turn on the water supply valve and check for leaks. Here is a video tutorial that demonstrates how to install a water line to an ice maker or refrigerator using a 5 foot hose with 1/4 inch compression fittings. INSTALLING ICE MAKER / REFRIGERATOR WATER LINE - using 1/4" compression hose (youtube.com)
2/15/2024 9:40:38 PM • Maytag... • Answered on Feb 15, 2024
Maytag 2 door fridge has only water for ice cubes. Is there a water filter for the ice?
you can add water filter. It is installed on supply line. go to Home Depot and pick up a refrigerator water filter kit with accessories.
10/19/2023 1:58:54 PM • Maytag... • Answered on Oct 19, 2023
I got some ice from the doors ice and water dispenser I heard the ice maker turn over then instead of water going into the ice maker to refill it began coming out the door water dispenser.
inspect the ice make to check for any sign of visible damage or misalignment, .and unplug the fridge and plug it again
8/23/2023 5:17:05 PM • Maytag... • Answered on Aug 23, 2023
Where is the defrost timer on Maytag top freezer RTD21E0CDL
Matthew...you sure you have the Model# right? Cuz Google comes up with Zip..Zilch with that #.? :)
8/15/2023 5:37:38 PM • Maytag... • Answered on Aug 15, 2023
My Maytag MZD2768GE frezzer side is forming ice on the bottom. Water is coming out of the lower vent.
Fridge/freezer freezing up- and no fan or air circulation: first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice. AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature. May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section. u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad? Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next. Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance.. Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS . Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area! THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required Freezer /fridge leaking water/ice frozen in fridge and or freezer, or leaks on floor Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out. Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it. Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor. However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up. Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also. Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer. God is so good: so this is why I give free advice so please thank him not me. OTHER THINGS TO CHECK ARE THE DEFROST TERMINATOR AND THE HEATER ELEMENT FOR COBNTINUITY. defrost timer location defrost terminator-undefined-undefined-0_2.jpg door seals cracked-fridge-seals-undefined-undefined-1.jpg drain center drain holer-undefined-undefined-2.jpg drain hole freezer downside-undefined-undefined-3.jpg evaporator-fan-blade.1280x600-undefined-undefined-4_0.jpg
7/26/2023 8:07:17 PM • Maytag... • Answered on Jul 26, 2023
Does the Maytag Model: MSD2651KES have a drip pan underneath?
The Maytag Model MSD2651KES is a side-by-side refrigerator. It does not have a traditional drip pan underneath like some other refrigerator models. Instead, it uses a drain system to collect and channel condensation and defrost water. The condensation and defrost water from the freezer section of the refrigerator typically flow down through a drain hole and into a drain pan or trough located at the bottom of the refrigerator. This drain pan is usually not accessible from the outside and does not require regular maintenance or emptying. If you are experiencing any issues with water leakage or pooling around your Maytag refrigerator, it is recommended to check the drain system for any blockages or clogs. Ensure that the drain hole is clear and that the water can flow freely through the system. If you suspect a problem with the drain system, it is advisable to consult the refrigerator's user manual or contact Maytag customer support for specific guidance on troubleshooting and resolving the issue.
6/28/2023 2:44:00 AM • Maytag... • Answered on Jun 28, 2023
Oil coming from the inside of my Maytag refrigerator door?
Either the compressor is broken or is now compromised.The compressor needs to now be replaced for your fridge.
5/10/2023 7:12:14 AM • Maytag... • Answered on May 10, 2023
2answers
Water pooling at bottom, how do I find out why?
Water is pooling at the bottom of your refrigerator because the drain in the freezer is clogged, probably with ice. You need to turn of the refrigerator and empty the freezer. Remove the cover in the bottom of the freezer by first removing the back cover of the freezer and then the bottom cover. You will probably see it full of ice. Remove this ice by chipping, or if you have time, let it thaw. Then, located the drain in the back of the compartment below the coils, and thaw it. You can use a hair dryer for this. Eventually, you will see the water drain, and you can dry everything up and put it back together. You should have no more problems. If you do, then you need to look at testing the defroster.
4/24/2023 3:40:07 AM • Maytag... • Answered on Apr 24, 2023
I replaced my HV control board on my Maytag MFI2067AES and programmed the code from my refrigerator but the code is not being saved. Do I have the wrong board?
If you have replaced the HV control board on your Maytag MFI2067AES refrigerator and programmed the code from your refrigerator, but the code is not being saved, there could be a few possible causes:
  1. Wrong board: It's possible that you may have installed the wrong control board for your refrigerator model. Make sure to double-check the part number and compatibility before installing a new control board.
  2. Improper programming: Make sure that you are properly programming the control board with the correct code. Follow the manufacturer's instructions carefully and ensure that you are entering the code correctly.
  3. Control board issue: It's possible that the control board itself may be defective and is unable to save the code. Try resetting the control board to factory defaults and reprogramming it with the correct code. If the issue persists, you may need to replace the control board again.
  4. Other issues: There could be other issues with your refrigerator that are preventing the code from being saved, such as a faulty user interface or a problem with the door switch. You may need to perform further diagnosis or seek the help of a qualified repair technician to identify and fix the issue.
3/17/2023 8:05:57 PM • Maytag... • Answered on Mar 17, 2023
Maytag refrigerator control panel
It's possible that the issue is with the control board and not just the control panel. Before replacing the control board, here are a few things you can check:
  1. Make sure the control panel is properly connected to the control board. Check the connections and make sure they are secure.
  2. Check for any damaged wires or connectors. Look for any signs of damage, such as frayed wires or loose connectors.
  3. Check the voltage to the control board. Use a multimeter to check the voltage at the control board. If there is no voltage, there may be an issue with the wiring or power supply.
  4. Check the fuses on the control board. If the fuses are blown, the control board will not function properly.
If none of these steps resolve the issue, it's possible that the control board is faulty and needs to be replaced. However, it's important to note that diagnosing and repairing electrical issues can be dangerous and should only be attempted by qualified professionals. If you're not comfortable working with electrical components, it's best to seek the help of a certified technician.
3/15/2023 4:32:15 AM • Maytag... • Answered on Mar 15, 2023
Maytag MTF2156GEW Top Freezer Refrigerator Logo
Popular Tags
13 questions posted
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
freezer gets cold refrigerator doesnt
  • Refrigerators
