20 Most Recent NorStar T7316E Telephone Questions & Answers
user and password ?? try admin (23646)
or user setnna (738662) and pass 23646 or 266344
NorStar T7316E... | Answered on Aug 20, 2015
No, you need a system, it's a digital phone and your home phone is analog.
NorStar T7316E... | Answered on Jul 22, 2015
The system should be configured so that the desired lines, whether CO or extensions, are set to "Appear and Ring" on each set.
Config... Terminals&sets... Show Set... (enter #)... Find...Line Access... Line Assignments... Show Line (enter #)... set to "Appear and Ring" on each set that needs to ring.
You can also have a line "Ring Only" without an appearance (dedicated button), in which case it will show as an intercom call.
NorStar T7316E... | Answered on Oct 06, 2014
It is the button above the redish hold button. Gray in color with a circle type of desi.
NorStar T7316E... | Answered on Feb 09, 2014
If your voice mail system is a Call Pilot on a BCM phone system. Use Feature 983, enter the Log number 738662, enter the password set for the system. At this point the display should show Admin with options MBOX -- AA -- OTHR select MBOX. Select CHNG and enter the mailbox number which should be the same as your extension number. The display should now show Password with options of RESET and NEXT. Select reset and your password will be reset to 0000. Press the release button and call into your mailbox using the password 0000. The system will have you change your password and verify it. Hopefully this will fix your problem.
NorStar T7316E... | Answered on Feb 06, 2014
Press the Feature button and *80. Adjust the volume and press the release button. If it still doesn't ring make sure your not in Do Not Disturb mode. Feature #85 should clear this.
NorStar T7316E... | Answered on Jan 27, 2014
You need to ensure that the main bell is programmed to ring, also that the extensions are also programmed to ring as well. Also check that the ringer is switched on, on the base of the telephones. Also ensure your handsets to not go over the ren value permitted. Make sure the service is on the correct day service and not night service. Check that the handsets ring internally and ensure they are registered with the system. Ensure that the connections and wiring are also correct,
NorStar T7316E... | Answered on Mar 16, 2013
# cancels.
i.e F4 is forward and F#4 cancels the forward.
You can also press Cancel on the softkey/Display on the larger sets
NorStar T7316E... | Answered on Dec 19, 2012
Look at the bottom of the set that is giving you troubles, check to see if the handset is plugged into the correct spot.
It should be plugged into the Handset jack not the headset jack.
This is a common mistake.
NorStar T7316E... | Answered on Apr 10, 2012
Ok, first of all the general Mailbox is 100 for 3 digit extensions or 10 of 2 digit extensions.
How to Change a Mailbox Password
1. To access the voice mail system press "Feature".
2. Press "983".
3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers.
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
9. Press "Rls" to exit (orange button to the right of the number buttons).
Default password is "0000".
NorStar T7316E... | Answered on Dec 22, 2011
Look at your Administrator manual for the FEATURE **TIME command.
Carl
NorStar T7316E... | Answered on Mar 23, 2011
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
NorStar T7316E... | Answered on Jan 05, 2011
Its mic is damaged which is on the lower side of the hand set
NorStar T7316E... | Answered on May 21, 2010
To reset your voice mail password,on press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
NorStar T7316E... | Answered on Apr 28, 2010
how long are your digits 2 digits exts are 120000
3 digits are 1020000 and 4 are 10020000
NorStar T7316E... | Answered on Feb 23, 2010
Place your first caller on hold, call the second person to on the conference, press the conf key (or feature 3) and press the held linewith the first caller.
NorStar T7316E... | Answered on Nov 23, 2009
NorStar T7316E Telephone Logo
47 questions posted
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
  • NorStar Lands Phones
Most Popular Question
norstar t7316e phone work home phone
  • Lands Phones
