20 Most Recent
OEM Systems Motorola Bluetooth Headset , HS820 [OEM] 98627H Headset Questions & Answers
Can i pair bluetooth to xbox 360
Yes , but it will have to be a Bluetooth for the XBOX360 which is sold along with other controllers etc. in the store . Not be confused with a Bluetooth that you would use with a cell phone
How does one turn on a Motorola 537w bluetooth
To power
your headset on, press and hold the Multifunction for 3 seconds until LED
flashes rapidly.
To turn your
headset off after use, press and hold the Multifunction button for 3 seconds
until the headset flashes rapidly and turns off.
Hope it
helps
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
19 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
