20 Most Recent Palm Z22 Handheld Questions & Answers
Hi AnyMoose:
I list 3 ways to fix the touch screen on a Z22. People on fixya list a credit card method. 4 ways to get the screen working. More tips and maintenance at:
http://kidbots.com/WEBADD/Z22_PALM_PILOT/Z22_PALM_PILOT.html
good luck
robin dusty graves
Palm Z22... | Answered on Jan 28, 2019
Hello ariuz1953
Your solution is to simply Factory Reset the Z22, and put in your own new name and password. I have most answers to all Z22 questions. see:
good luck
robin dusty graves
Hello AnyMoose
I am guessing that 6 years ago, when you posted your "QUESTION", you upgraded your Windows to Operating System to a newer version that is not supported. I cover a number of solutons to the problem at:
It is rare to find anyone still using a Z22 these days. ( I use mine every day)
good luck
robin dusty graves
Hi, erieser,
If your new ( used) Z22 has a name "missy", then it is NOT A "BLANK", as you state! You need to do a complete "factory Reset" After the COMPLETE factory reset, you then start the Z22 and name it Absolutely identical to your computer's Z22 name, and then try again to connect. I am surprised that fixya.com did not direct you to my 32 other Z22 answers, which cover your question. You can read about your answer and other tips and maintenance procedures at
good luck
robin dusty graves
Replace it.
You may be charging the Palm, but the computer thinks you are tiring to make a connection and communicate. It seems your computer needs drivers to correct the problem.
Palm Z22... | Answered on Feb 01, 2018
Yes it can be repaired. It might not be worth it though with parts and labor. Depends how new it is.
Palm Z22... | Answered on Sep 17, 2017
behoney56:
The information support page for the Palm Z22 has moved around over the past few years. It is now at
http://kb.hpwebos.com/wps/portal/kb/na/zire/z22/unlocked/home/page_en.html
As well, I have an entire web page devoted just to maintaining, repairing, and using the Palm Z22, at:
As the Palm Z22 ages, there are issues with old and dying batteries, with the touch screen deforming and becoming useless, and various DATA connectivity issues, since the new Windows 64 BIT Operating Systems did not yet exist when the Z22 was diss-continued.
On my web page are links and USER information on the various solutions that they found, as well as a bit of information that I discovered, which is hitherto unknown!
Hope these tid-bits of help get your Palm Z22 up and running properly...
good luck
robin dusty graves
lost-cd-cdqazwk5fkdpm30unkbxcrm5-1-0.jpg Z22 PALM PILOT lost-cd-cdqazwk5fkdpm30unkbxcrm5-1-1.jpg
Palm Z22... | Answered on Nov 27, 2014
Hi rick:
There are 3 main problems with the "AGING" Palm Z22, and one of the most common is the failing touch screen. Lucky for you, there are a number of ways of dealing with this, from a temporary fix (emergency) of Freezing the unit, to Heating the screen, to ripping it apart ( no, I am not kidding!), to simply replacing the screen for $9 U.S., (free shipping from Hong Kong)....
If you are experiencing touchscreen issues, then you are going to be having BATTERY problems as well, so the information on these, and other issues will help you to get up and running, and stay that way...
Hope this information helps
good luck
robin dusty graves
Z22 PALM PILOT tapping-feature-handhell-zire-22-cdqazwk5fkdpm30unkbxcrm5-3-0.jpg tapping-feature-handhell-zire-22-cdqazwk5fkdpm30unkbxcrm5-3-1.jpg tapping-feature-handhell-zire-22-cdqazwk5fkdpm30unkbxcrm5-3-3.jpg tapping-feature-handhell-zire-22-cdqazwk5fkdpm30unkbxcrm5-3-6.jpg
Hello there Anymoose:
On my web page:
are many suggestions and links to help get DATA SYNC's to your computer.
Please search the internet for CompanionLink as well, since I just discovered it now, and have not yet added it to my web page...
As well, I cover aspects such as the battery, the touchscreen, and other quirks that happen as the Palm Z22 gets older and older!
I hope this information solves your problems...
good luck
robin dusty graves
Z22 PALM PILOT hotsync-function-dies-not-work-cdqazwk5fkdpm30unkbxcrm5-1-0.jpg hotsync-function-dies-not-work-cdqazwk5fkdpm30unkbxcrm5-1-1.jpg hotsync-function-dies-not-work-cdqazwk5fkdpm30unkbxcrm5-1-3.jpg hotsync-function-dies-not-work-cdqazwk5fkdpm30unkbxcrm5-1-6.jpg
Hello AnyMoose:
I have an entire web page covering many issues with the Palm Z22, and data connectivity is one of them. The ANSWER above of the CompanionLink software is one which I had not seen until now, and I will add it to all the resources listed on my page...
Other solutions include the software from ACEECA, the PALM Z22 connection software from Hewlett Packard, in conjunction with the Virtual Windows XP software, with technical notes from USERS, all listed on my web page...
Hopefully, once you read over all the data, you will get all the data to- and from- your Palm Z22...
As well, tips and suggestions are included on the Battery problems, the touch screen issues, and other quirks with the Z22 as it ages!
hope this helps...
good luck
robin dusty graves
Z22 PALM PILOT need-handheld-overwrite-desktop-sync-cdqazwk5fkdpm30unkbxcrm5-4-0.jpg need-handheld-overwrite-desktop-sync-cdqazwk5fkdpm30unkbxcrm5-4-1.jpg need-handheld-overwrite-desktop-sync-cdqazwk5fkdpm30unkbxcrm5-4-3.jpg
BONJOUR!
Sorry, je ne parle bien! I only started French at grade 9, and my Grade 10 French teacher transferred me to Auto Mechanics, so languages are not my gift...
If you can translate from English, or have a friend translate, then see my entire web page devoted to the PALM Z22, at:
I cover topics such as battery replacement, touch screen failure, software connectivity, maintenance, and repair...
hope the information is of value
bon chance
robin dusty graves
Z22 PALM PILOT comment-changer-la-batterie-cdqazwk5fkdpm30unkbxcrm5-2-0.jpg comment-changer-la-batterie-cdqazwk5fkdpm30unkbxcrm5-2-1.jpg comment-changer-la-batterie-cdqazwk5fkdpm30unkbxcrm5-2-3.jpg comment-changer-la-batterie-cdqazwk5fkdpm30unkbxcrm5-2-6.jpg
Hi suzbt:
JOY's answer, that you try to do a SYSTEM RESTORE on your Computer to get the data back is a really good one, that I did not think of! All manual instructions, and USER instructions on doing a SYNC with the Palm Z22, REPEAT : 1/ Always have a back up of the hard data 2/ Always check all transferred DATA on a SYNC, "Even if it states 'transfer Successful'", 3/ Even, if necessary, write down the data, ...
There are a few software programs to identify FILE problems on the Z22, listed on my web page:
and ways to recover corrupt data, but these are getting more and more difficult to find and use...
User comments on the SYNC indicate that any SYNC is a risky procedure, and backups and re-checking all data is necessary at all times.
I hope that the information on my web site comes in useful in keeping the Palm Z22 up and running!
good luck
robin dusty graves
Z22 PALM PILOT recover-lost-calendar-events-palm-z22-cdqazwk5fkdpm30unkbxcrm5-2-0.jpg recover-lost-calendar-events-palm-z22-cdqazwk5fkdpm30unkbxcrm5-2-1.jpg recover-lost-calendar-events-palm-z22-cdqazwk5fkdpm30unkbxcrm5-2-3.jpg
Hello de nicola:
I have an entire page devoted just to the Palm Z22, listed below.
Many people report issues with trying to connect the Palm Z22 to new 64 BIT Operating systems like Windows 7 and Windows 8, and although somewhat obscure and time-consuming to set up, this can be done. ONE known software company has a 64 BIT driver, which, when used with other software, can get the SYNC functions working again. Another method is to put a VIRTUAL Windows XP on the Windows 64 BIT Systems, and then SYNC using the already working WIndows XP to get the data from files on the "new" 64 Bit Systems, and back...
I also deal with battery problems, touch screen problems, maintenance, repair, and upkeep issues, so that you may find the page of value! It is at:
I hope this gets your Palm Z22 up and running again, and keeps it that way...
good luck
robin dusty graves
Z22 PALM PILOT transfer-data-from-z222-window7-cdqazwk5fkdpm30unkbxcrm5-3-0.jpg transfer-data-from-z222-window7-cdqazwk5fkdpm30unkbxcrm5-3-1.jpg transfer-data-from-z222-window7-cdqazwk5fkdpm30unkbxcrm5-3-3.jpg
Hi topplady:
The SYNC CABLE for the Palm Z22 is just the everyday, ordinary, USB "MIMI" cable that all USB devices like cell phones, MP3 players, etc. used for years. These used to be plentiful in 'dollar' stores, but have been replaced with the "MICRO" plug which is much thinner, so you may have to look around. I find piles of them in "Value" "Thrift" type stores now, since they are falling out of popularity, but they are everywhere if you take the time to look - and, since they are getting obsolete, they are really cheap... You can go online and look for " MINI USB CABLE" on Amazon, eBay, etc. where they are readily available...
I have an entire page devoted to the maintenance, up-keep, repair, and connection of the Palm Z22, so you can check it out for more tips, hints, suggestions, and information...
at:
Z22 PALM PILOT lost-sync-cable-palm-z22-need-cdqazwk5fkdpm30unkbxcrm5-1-0.jpg lost-sync-cable-palm-z22-need-cdqazwk5fkdpm30unkbxcrm5-1-1.jpg lost-sync-cable-palm-z22-need-cdqazwk5fkdpm30unkbxcrm5-1-3.jpg
Hello cskennedy:
Many people are asking the same question, as well as how to deal with touchscreen and battery problems etc.
I have really explored all the aspects keeping a Z22 up and running, and have a complete web page devoted to this.
I am repeating a previous answer below:
The support page for the Z22 has moved around over the last couple of years. HP (Hewlett Packard) bought PALM and still has a fairly good coverage of what WAS available. Beware that Windows has gone to 64 BITS with Windows 7, Windows 8 etc, so that older software does NOT immediately work.
There are many features of the Z22 such as NEWS and GAME web portals that are shut down, so that peripheral connectivity is at a minimum.
HP has the last known working, native, connection software at:
On my web page at :
I have all the patches, fixes, work-arounds, maintenance, tips and tricks I could find.
Hope that this helps you to get your PALM Z22 working and useful once again!
good luck
robin dusty graves
Z22 PALM PILOT computer-went-down-lost-calender-info-cdqazwk5fkdpm30unkbxcrm5-3-0.jpg computer-went-down-lost-calender-info-cdqazwk5fkdpm30unkbxcrm5-3-1.jpg computer-went-down-lost-calender-info-cdqazwk5fkdpm30unkbxcrm5-3-3.jpg computer-went-down-lost-calender-info-cdqazwk5fkdpm30unkbxcrm5-3-6.jpg
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/solutions/article/40774_en.html
If you look through you can download software without the cd.
Hope it helps.
Hello there, you can get the main software for the Z22 from the following link:
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/solutions/article/32859_en.html
Just use the big Download button at the top.
Thanks
Tim
I am repeating a previous answer, since it covers most of the common problems :
The Palm Z22 is, I have found out, a bullet-proof design in regards to reliably keeping your valuable "DATA" safe over time. The Engineers at PALM really did a good job of Data integrity compared to many other devices. HOWEVER -- there are 3 common problems with the growing AGE of the Z22, 2 are with the dying batteries, and 1 with the years of wear and tear on the touch screen. The battery is a typical square, thin, modern Lithium battery, wired in with two wires ( + positive, red, and - negative, black ) that can be
taken out and replaced if you take the unit apart. In a brand new, in-the-box package, the battery is dying simply from old age. If the Z22 was used heavily, the constant cycling from dead to fully charged wears out the battery even more. The Touchscreen is a thin layer of plastic stretched over a sheet of glass, with a tiny air gap in between. Over time, the top plastic layer deforms - with hot and cold, air pressure changes, and being pressed by wearing the unit in a pocket, purse, briefcase, or even in a drawer with pencils, pens, and staplers etc. It is very important to have a hard cover over the screen! Other than just having the battery loose its weak charge continually, there is a problem with the unit getting into a state of BLACK SCREEN - it does not charge and remains "apparently" dead, since the logic circuits are in an invalid state, and it can only be reset if the battery dies COMPLETELY to remove the power on the logic circuits.
I have covered the topics of the battery problems, the data problems, the screen problems, and the disassembly, maintenance, and security, and how to get data off the unit, particularly to the new Windows Operating Systems that were developed AFTER the Z22 was no longer made. This is at
I have ripped apart the Z22 repeatedly, and posted pictures of the various steps to service these units. There are links to aftermarket software to transfer data, and examples of how to USE the Z22, for valid purposes. This should be a one-stop source for any information or troublehooting the Z22, for those who have the Z22 and want to keep it operating!
good luck
robin dusty graves
Z22 PALM PILOT
Z22 PALM PILOT fix-touch-screen-palm-z22-ngl0e1lc0ft3j10pmz4xzklk-4-0.jpg fix-touch-screen-palm-z22-ngl0e1lc0ft3j10pmz4xzklk-4-1.jpg fix-touch-screen-palm-z22-ngl0e1lc0ft3j10pmz4xzklk-4-3.jpg fix-touch-screen-palm-z22-ngl0e1lc0ft3j10pmz4xzklk-4-6.jpg
Palm Z22... | Answered on Nov 17, 2014
Palm Z22 Handheld Logo
320 questions posted
Popular Products
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Palm Computers & Internet
Most Popular Question
palm z22 touch screen not responding
  • Computers & Internet
