20 Most Recent
Maytag MSD2756GES Side by Side Refrigerator Questions & Answers
Maytag msd2758ges ice maker squirts water
Sounds like the water solenoid is not shutting off cause once the tray fills it should stop sending water located in the back bottom with the water lines connected
3/24/2013 4:44:04 AM •
Maytag...
Answered
on Mar 24, 2013
Ice and water switch won't turn off
I went back into the files here and found a good bit of info, hope there's something to help! http://www.fixya.com/search/p45578-maytag_msd2756ges_side_by_side/button
2/16/2013 11:09:00 PM •
Maytag...
Answered
on Feb 16, 2013
Maytag MSD2756GES fridge not dispensing water or making ice
The first thing is how long has it been since you've changed the water filter. Its odd that both would stop at the same time and usually this is what causes it. If you change it and the problem persist continue to the next steps:
Pull the machine out and remove the lower back cover. Locate the water valve. With the water turned on and connected remove the 5/16" water line (the bigger one) and then have someone else press the water in the door. If the cylinoid is operating correctly it should spray water out. If it is not operating properly it should at least hum and vibrate. BE SAFE IN DOING THIS NEXT STEP. With the machine plugged in but the wires that go to the valve for the dispenser off take a volt meter and place a lead to each wire and have someone press the panel in the door as if getting water. The reading should go from 0 to around 115-120 a/c.If your not getting electricity down there at anytime than thje door switch is bad. As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/jason_4570d45317834dd3
5/9/2012 12:13:55 PM •
Maytag...
Answered
on May 09, 2012
